Can't fill gas tank after charcoal canister was removed for cage
Old 04-18-2013, 02:47 PM
z06801
z06801's Avatar
Default Can't fill gas tank after charcoal canister was removed for cage
Anyone had this problem? will this lead to other problems than just filling the tank?
Old 04-18-2013, 05:06 PM
fatbillybob
fatbillybob's Avatar
I have not monkeyed with this system in vettes but becareful. The fuel system is a carefully engineered system that has safety features we don't even know are there. Often we racers remove stuff that make us less safe. Use extra caution with Fuel systems. Even the charchol canister is more than a smog device. Often it has a series of fittings and hoses all to make a sealed system. Improper removal can result in fuel fires and fuel leakage in crashes. For example an upside fuel bath could end your life.
Old 04-18-2013, 05:37 PM
z06801
z06801's Avatar
thanks, those are the kinds of concerns I started to have when it wouldn't take gas at a normal rate.
Old 04-18-2013, 07:49 PM
Lawdogg
Lawdogg's Avatar
What did you do with the vent tube on the top of the tank? If that is capped or plugged it will take a long time to fill the tank.
Old 04-18-2013, 09:56 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
you need a vent with a ball valve (in case you roll over). You somehow plugged your vent.
Old 04-18-2013, 10:01 PM
RapidC84B
RapidC84B's Avatar
Received 13,165 Likes on 5,989 Posts
Lines were probably capped. Take rubber flapper cover off in passenger rear wheel well and see if those two lines are capped... fairly easy to get to. The top of the tanks are vented to atmosphere even when the charcoal canister is connected.
Old 04-18-2013, 11:25 PM
z06801
z06801's Avatar
Thanks for the ideas guys, I'll check that out
Old 04-19-2013, 01:21 AM
z06801
z06801's Avatar
f those lines are capped, should they just be uncapped to tied in a vertical direction or should they have some sort of breather?
To Can't fill gas tank after charcoal canister was removed for cage
Quick Reply: Can't fill gas tank after charcoal canister was removed for cage
