HANS Adjustable vs Hybrid Pro Rage
Old 04-23-2013, 01:26 PM
Grabbed_Crow_Mobe
Grabbed_Crow_Mobe's Avatar
Default HANS Adjustable vs Hybrid Pro Rage
I’m in the market for a neck restraint and have narrowed it down to these two. Anyone have any pros/cons between the two? Should I consider something else (besides defender-see below)?
Current seat/safety setup:
Sparco Evo 2 Plus seat
Hardbar seat rails
Sharkbar harness bar
Teamtech Jet Pilot harness (3” belts all around)
Bell Sport Helmet
Note - Because of the sternum strap on my harness, the defender is not an option. I called them and they don’t support the use of a sternum strap.
Any advice would be appreciated!
Thanks,
Kevin
Old 04-23-2013, 04:25 PM
LanceFitzgiben
LanceFitzgiben's Avatar
Given that the sparco has harness pass-throughs.. is there another reason that I'm not thinking of that you'd run a sternum strap?
Old 04-23-2013, 04:44 PM
Grabbed_Crow_Mobe
No other reason than it's integrated into my harness:
Probably not required. I originally bought this harness thinking I could use it with stock seats. It did a job job of holding my upper body in place but my legs still thrashed around a lot. Getting the Sparcos solved that problem.
To HANS Adjustable vs Hybrid Pro Rage
Quick Reply: HANS Adjustable vs Hybrid Pro Rage
