lube for rear end
I had a bad experience with that lube in a Dana 44.
Had a really good shop build it right, and was there when he did it, it was built tight just like I wanted. Put in that lube and in three autocross weekends it was slipping and the clutch packs wore out in short order.
Once a LSD clutch starts to slip wear is pretty fast. I've had better diff clutch life with the factory fill and the friction modifier.
Just my experience.
Just my experience.
