Replacing C6 calipers
Old 04-26-2013, 02:05 PM
avizandum
avizandum's Avatar
Default Replacing C6 calipers
Want to do this myself. Will I necessarily need a Tech II bleeding? (Replacing lines too)
Old 04-26-2013, 02:49 PM
Scooter70
Scooter70's Avatar
No. A Tech2 bleed is only to pulse the ABS pump if you get air in it. Since you're way down stream of there you're only concerned with the air in the caliper.
(BTW, I live in Farmington too.)
Old 04-26-2013, 04:05 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
I bleed all the time without bleeding the ABS pump on our C5Z & C6Z, and I just changed out the calipers on our C5Z to the AP Racing T1 set, bled the system and have had no trouble. Eventually as you get into ABS enough times the fluid will mix and you'll bleed it out... naturally.
Old 04-26-2013, 09:53 PM
spdislife
spdislife's Avatar
Rebuilt and replaced numerous calipers and always bleed in between events and have never had an issue
To Replacing C6 calipers
Quick Reply: Replacing C6 calipers
