Show me your Spal fan setup
Track Junky
Hey guys,
I now have a 2001 C5Z track only car and would like to swap to a single Spal 16" fan in place of the stock shroud. I've done a bit of searching, but the info is not all in one place that I can immediately find. Please post up what you guys have down with part numbers, websites (I heard that there are some used NASCAR websites that sell these but I can't find any), connector type and part numbers, wire gage, any type of zip tie you used (metal or plastic).
Thanks in advance for any info.
Sean
Sean
Track Junky
Hey trackboss where'd you get that fan? I'm assuming you got it hooked up to a switch inside the car? Ben whatever info you got, post it up here. I've got the car apart waiting on a short block and I'm itching for projects to keep me busy in the meantime!
I don't track my car but I have the Dewitts SPAL setup....those bitches move some air
http://the-fan-man.com/
I wired my fan using the factory wiring. Made a special connector to attach the the one no longer used. Removed the "high speed" relay that is no longer needed. Everything works just like stock, but performance is improved.
One thing I like about the way I mounted it is that it does not use any of the crappy brackets that are usually associated with mounting these types of fans. I hammerformed a pair of "S" shaped brackets and welded them to the radiator. The fan has flat spots on 4 sides. I used two of those for the brackets to line up to. A third one butts up against the edge of the core/tank. Installed threaded inserts in the fan housing 180* apart (top/bottom) and two 1/4' screws hold the fan on. Very simple to remove/install. Lightweight, and solid. Plus, no bracketry to obstruct air flow.
I'd love to see any pictures you have of that setup. Did you lay the radiator forward? If you lay it forward, do you need to use hood pins or can you keep the stock hinges? The fan pulls, correct?
Thanks again
Thanks again
Flex a Lite 118 puller.
2500cfm = no need for a shroud (so better cooling at speed) and a bit lighter than the stock setup.
Hook it up to the low speed fan connector -- so the computer will always turn this fan on (assuming the temp and mph parameters are met), whereas the high speed fan only gets turned on when the computer decides the low speed fan is not doing an adequate job.
2500cfm = no need for a shroud (so better cooing at speed) and a bit lighter than the stock setup.
Oh. I've had bad luck with those zip ties in the past, refuse to use them anymore. I was thinking of a rivnut on the top and bottom, maybe a padded zip tie to stabilize the sides, but allowing the zip ties to bear the weight of the fan is asking for trouble. They'll rub through the passages in the radiator and spring a leak. The fan shakes about when it's running which exacerbates the problem.
I used them for 2 years, 20k miles, 15 track weekends, holding an oil cooler to the front of a DeWitts radiator and a fan to the back.
YMMV.
YMMV.
moespeeds, if you are referring to my setup I did not lay it forward, even though I wanted to. My car is a street car and if I did that I would have had to modify the air inlet for the motor and possibly run into smog issues so I chose to mimic the factory orientation keeping appearance low key although the radiator is custom and so is it's mounting. I chose to build my radiator from a generic griffin circle track radiator. Next time I'll just buy a core and build everything myself rather than add to one with existing tanks. It is a double pass so I use the factory upper hose and built a custom lower. Also, dual row, 1" wide tubes is considered about as thick as a core as could be used on the street, but I went with 1.25" dual row and after some testing I now know I could have probably went with even wider 1.5" rows and not had an air flow problem. The key is low fin count. IMO, the spal fan I used pulls more air through this setup than the factory fans pull through that system and I do have a condensor in front of the radiator. There is noticable suction at the radiator inlet under the nose. I let the car run for almost a half hour sitting still and played with the rpms to get the water as hot as possible yet it did not get hot. The fan came on as programmed and it took just a minute or so for the temp to drop enough for the fan to go off. Someday I'll program the fan to come on much later. Right now it comes on about 195 or so if I remember correctly. I'd rather it be triggered about 215-220 so it is not always cycling.
Let me explain the "high speed" system from the factory for those that are not familiar. There are 3 relays. One goes on at "low speed". It runs BOTH fans in series. Because of that the voltage drops so each fan runs slower than if it were getting a full 12 volts simply because there is twice the draw on one circuit. When "high speed" is triggered a second relay is turned on and the third simply switches grounds so that the fans run in parallel and each get full power from their own relay.
