Brake Cam - C6 Wheel Well
Old 04-30-2013, 09:42 PM
CONE RACER
CONE RACER's Avatar
Default Brake Cam - C6 Wheel Well
Had a fun day at Atlanta Motorsports Park on Monday so we had some time to play around with the cameras a bit. Here's a quick clip (30 seconds) from the left front wheel well in my C6 from about 6 minutes into the session. Brake temps were a little higher around 15 minutes, but not significantly. The video shows front straight, entrace to T1 thru entrance to T3. Stock rotor with Carbotech pads and Brembo LCF 600. I've been running this set-up for about a year, and I was interested to see what was really going on down in there. Always had excellent performance. This was the fourth event on the front rotors. They're done, but after seeing how they glow in the video, it seems like a reasonable expectation out of them. Kind of cool. Choose high def and full screen - it shows some good detail.
Old 05-02-2013, 01:37 PM
Toilets
Toilets's Avatar
That is really cool. Thanks
Old 05-03-2013, 12:28 AM
crimlwC6
crimlwC6's Avatar
Mind sharing what camera you used for that?
Old 05-03-2013, 10:33 PM
CONE RACER
CONE RACER's Avatar
We put a GoPro sticky mount on the frame rail and hung the camera on that. Just turned the wheel to lock, reached in and clipped it on just before we went out. Super easy. I'm thinking about other places to try - foot well/pedal area, rear suspension, engine compartment, etc...
Old 05-05-2013, 12:31 PM
crimlwC6
crimlwC6's Avatar
Wow. I have the first version of the GoPro with HD and I'm surprised at how well your camera handles the light difference. Thanks!
To Brake Cam - C6 Wheel Well
Quick Reply: Brake Cam - C6 Wheel Well
