C6 ZO6 Race seats
Old 05-01-2013, 02:13 PM
5280Racer
5280Racer's Avatar
Default C6 ZO6 Race seats
Hey guys I know I have serached and not really found what I am looking for.. i would really appreciate you guys to post pics and pro and cons of different seats you run in your cars.. I'm 6' 200 36 waist..and tired of sliding around!!!
Old 05-01-2013, 04:01 PM
Bluefire
Bluefire's Avatar
I installed the Corbeau FX1-Pro seats. PIA to install in the correct spatial orientation (height/angle) but it was well worth it.
http://forums.corvetteforum.com/c5-t...n-sliders.html
Old 05-01-2013, 06:05 PM
66L72
Support Corvetteforum!
66L72's Avatar
You are my twin.
I got a great deal on a set of Caravaggio carbon race seats. They look great and are very supportive and comfortable. However since they don't have a center cushion pass through for the crotch belts NASA made me use the standard 3 point OEM belt and sit on my sharkbar/GForce set up
Good luck
Old 05-01-2013, 07:45 PM
GOTHAM VETTE
GOTHAM VETTE's Avatar
Take a look at lg's race seats.
Old 05-02-2013, 09:00 AM
RedLS1GTO
RedLS1GTO's Avatar
At 6'0, 200, 36" you are almost my exact size.
I went with a Sparco Evo2 in my C5 on some custom made mounts to get it as low as possible.
It is a very good fit for me.
Old 05-02-2013, 02:42 PM
66L72
66L72's Avatar
Originally Posted by Bedouin
66L72, question on your Carravagios...did the 3 point factory seat belt still work alright with the race seats?
In other words, did the right & left lap portions of the lower belt lay flat accross your waist, or did the side of the caravaggios keep them elevated up/off of your waist? I'm 6' 190 lbs & am considering a set, & will most likely just run the stock seat belts.
Yes factory belts work fine. The plastic holders for the male and female parts of the belt come above the seat and go flat across your waist.
IMO the carbon race seats are ridiculously overpriced. I got mine in mint condition and my body color for less $2800 with no cores. The comfort, support and workmanship are first rate though. I was quoted $600 to put the crotchbelt pass through hole in the bottom cushion although I image it would be a lot less if he put the holes in during initial construction.
Good luck
To C6 ZO6 Race seats
Quick Reply: C6 ZO6 Race seats
