Mantic 7000 Triple Race Clutch
Old 05-01-2013, 06:32 PM
Wasserott
Wasserott's Avatar
Default Mantic 7000 Triple Race Clutch
Thought I'd share some pictures as I couldn't find any when i searched.
As I step back and look at what my money bought on this, pretty heck of a good deal....never mind the James Bond case it comes in, new throw-out bearing, slave cylinder, bleeder line, trick flywheel....Call Doug at East Coast Superchargers, he's again the real deal.
Old 05-01-2013, 07:07 PM
RX-Ben
RX-Ben's Avatar
Yup, its the real deal. I have one and it is the bees knees.
The key with the OEM TOB is using an unrestricted hydraulic line, which it looks like they are providing. It transfers the OEM TOB into a really nice setup.
I am a fan of the true flywheel setup - it is super high quality and light.
Be sure to install a remote bleeder while everything is out.
Old 05-01-2013, 07:08 PM
froggy47
froggy47's Avatar
How much?
Old 05-01-2013, 07:14 PM
Wasserott
Wasserott's Avatar
I believe that line is the remote bleeder, i didn't get another line.
Old 05-01-2013, 07:20 PM
RX-Ben
RX-Ben's Avatar
Ah, got it.
Run a -3an line from the clutch master to the slave. It is very easy. Ditch the OEM lines and fittings.
I'll dig up with you need and post later.
Old 05-02-2013, 11:39 AM
RX-Ben
RX-Ben's Avatar
To convert the OEM setup to AN lines:
(2) of these adapters (one for clutch master, one for TOB; note that they sold in pairs) - Russell Clutch Adapter Fittings 640281
(1) -3AN coupler (you could also not use this, simply avoids having to disconnect the hose at the master if you need to pull the driveline)
(1) short (~6") -3AN line with a 90deg and a straight end (this will hook up to the master)
(1) longer (~18") -3AN line with a 90 (I think) and a straight end (this will hook up to the slave, I think you need a 90deg fitting to get the line out of the existing hole in the bell housing though you may need to slightly notch the hole to ensure adequate clearance for the hose)
(if you don't use the union then just get one line with 2 90deg ends)
The lengths are off the top of my head, you should measure.
Also be sure to add some foil heat shielding to the lines.
Old 05-02-2013, 03:00 PM
Wasserott
Wasserott's Avatar
And what does this gain me vs OEM setup (beside a thinner wallet)
Old 05-02-2013, 03:49 PM
RX-Ben
RX-Ben's Avatar
It gets you a TOB that performs the same as a quartermaster tri-lite (in my experience).
With the stock TOB "unneutered" - by removing the in-line restrictor - it reacts instantaneously to clutch pedal inputs.
This can create more wear/tear on the driveline (by inducing more shock if you don't shift smoothly), but when properly driven you can pull off really quick shifts.
Old 05-03-2013, 01:58 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
With a case like that, I'll sick with my textrailia and shifts that are just as fast, considering is the driver, not the clutch
Old 05-03-2013, 09:43 AM
moespeeds
moespeeds's Avatar
The upside is that when you're done installing the clutch you can use the case to store your flux capacitor.
Old 05-03-2013, 09:57 AM
travisnd
travisnd's Avatar
Have you ever driven a car with a small clutch like this or a Tilton etc.? It's not about shift speed.
Old 05-04-2013, 07:18 PM
Woods
Woods's Avatar
I haven't so....
I'll bite....what's it about?
Old 05-05-2013, 05:37 AM
VGLNTE1
VGLNTE1's Avatar
Yup, not on a C5 though.
Old 05-06-2013, 12:28 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
Ah, got it.
I have found with the unsprung race discs like this, I prefer the OEM lines to give it a little give so to speak. We have installed them both ways, niether are bad, but I didnt change the lines on my own car if that helps.
Old 05-06-2013, 12:33 PM
DOUG @ ECS
DOUG @ ECS's Avatar
Thanks Chuck! We just finished up a meeting here with Mantic and plan to start stocking the 7000 series race clutch for our road racers now. Anyone interested can PM me for info.
I have seen the cases used for many things afterwards, I certainly wouldn't buy any performance part for it's casing, but hey it does come in handy later. When I travel with my tuning equipment I store them in Mantic cases, and myself and several of our customers use them for gun storage too.
Old 05-06-2013, 12:41 PM
DOUG @ ECS
DOUG @ ECS's Avatar
Originally Posted by Woods
I haven't so....
Lightweight, clean dissengagement on shifts. There is no comparison between this clutch and a Textrailia, they do not belong in the same conversation IMO. Overall purpose, quality of the product, and focus is in two different ball parks.
Old 07-01-2013, 08:31 PM
5280Racer
5280Racer's Avatar
How's the clutch doing???
To Mantic 7000 Triple Race Clutch
Old 07-02-2013, 11:32 PM
Wasserott
Wasserott's Avatar
I have it installed pretty straight forward, have not had on the track yet. Makes a little bit of noise disengaged and requires more binary action than a street set up. Probably won't be out on a track for some time as I'm moving and setting up a new job. Update next year unfortunately.
But i still say Doug is the best vendor i've dealt with in a while.
Chuck
Old 07-03-2013, 02:04 PM
DOUG @ ECS
DOUG @ ECS's Avatar
Chuck
Thanks Chuck! Good luck with the move.
Old 07-04-2013, 02:00 PM
sperkins
sperkins's Avatar
My street car has a textrailia (installed by previous owner) and I keep waiting on something in the driveline rear of the flywheel to break or start making noise so I'll have a good reason to get that stupid clutch out of there.
I can't believe people actually pay money for those things. It's by far the worst automotive related product (other than the ones [SPEC] that don't actually work) that I've ever had experience with.
Quick Reply: Mantic 7000 Triple Race Clutch
