View Poll Results: Which is harder on jacks?
Balancer
4.76%
Clutch
95.24%
Voters: 21. You may not vote on this poll
Which is harder to do (on jacks) balancer or clutch?
Old 05-01-2013, 06:36 PM
froggy47
froggy47's Avatar
Default Which is harder to do (on jacks) balancer or clutch?
Taking a survey so only post if you have done it or maybe if you own a shop. Don't post if you paid someone to do it.
Old 05-01-2013, 06:46 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I've done both on the floor, no contest
Old 05-02-2013, 01:14 AM
geerookie
geerookie's Avatar
I've done both as well. Damper is like changing a tire compared to a clutch.
Old 05-02-2013, 08:59 AM
waddisme
waddisme's Avatar
Old 05-02-2013, 09:45 AM
MR Turco
MR Turco's Avatar
i did the clutch on a lift, with a trans jack, and it wasn't nearly as bad as i thought. No way in hell would i even attempt it on jack stands. Kudos to those that do/have.
Old 05-02-2013, 10:37 AM
varkwso
varkwso's Avatar
I have done both on the floor, several times.
Old 05-02-2013, 10:38 AM
varkwso
varkwso's Avatar
Old 05-02-2013, 10:39 AM
drivinhard
drivinhard's Avatar
A wise person only does the clutch on the floor once, you must hate yourself
Old 05-02-2013, 11:07 AM
varkwso
varkwso's Avatar
A person with no lift height also does it more then once. Problem is now solved!
Old 05-02-2013, 11:49 AM
Paul Schmidt
Paul Schmidt's Avatar
Does popping the motor out (spun a bearing) from the top and swapping in a new clutch count? Had to do the balancer too. I have become more of a mechanic than a racer. My jack stands are getting more use than my helmet.
Old 05-02-2013, 12:00 PM
froggy47
froggy47's Avatar
Well this is turning out worse than I thought, probably looking at a clutch late this year. Or over winter break.
Old 05-03-2013, 12:12 PM
froggy47
froggy47's Avatar
Old 05-03-2013, 07:25 PM
dvandentop
dvandentop's Avatar
**** did the whole motor and clutch and slave swap on jack stands it really blows, hope ya only have to do it 1 time.
Old 05-03-2013, 09:35 PM
froggy47
froggy47's Avatar
It will only be once, looking for a c6z.
Old 05-03-2013, 10:11 PM
varkwso
varkwso's Avatar
I did an engine on jackstands. Clutch is worse....but takes less time.
Old 05-03-2013, 11:23 PM
taken19
Track Junky
taken19's Avatar
Dropping the drivetrain with jack stands on your back is no fun - done it 4 times in the past 2 years. Balancer/crank bolt is relatively simple in comparison.
Old 05-04-2013, 09:53 AM
varkwso
varkwso's Avatar
necessity drives the need. For my first one the local shop quoted $1100 labor, being cheap I said heck no. After I did it I thought they were spot on!
To Which is harder to do (on jacks) balancer or clutch?
Old 05-04-2013, 11:23 AM
drivinhard
drivinhard's Avatar
it's even worse/slower with long tubes
Old 05-04-2013, 01:32 PM
varkwso
varkwso's Avatar
Everything us worse with long tubes. I swear first step for radiator removal is "remove longtubes"
Old 05-04-2013, 01:51 PM
sperkins
sperkins's Avatar
I know a buy that did an engine swap on a 4-post lift.
What an idiot.
Quick Reply: Which is harder to do (on jacks) balancer or clutch?
