AIM Solo Feedback
AIM Solo Feedback
For those running an AIM Solo DT, how are you liking the unit?
Was it plug and play, and are you getting your monies worth?
Thanks for any feedback.
Still waiting for them to fix the steering wheel angle and brake pressure reading from the ecu.
Yep, that is a bit annoying. From what they said it works just fine on EU cars but does not work on US cars for some reason which they are trying to figure out. For the rest though I really like the system. Just took me a second to figure out how to get the DL to learn the proper gear ratio. skfx I'm also running mine with a smartycam and when it comes to ease of integrating data with video it can't get any simpler. Solo automatically turns the camera on, your data is overlayed automatically on video. Just download the files from your camera (or pull out the micro sd card) stick it on your laptop and you are viewing your last run in seconds.
The new HD version should be out in about a month if you want that. I just picked the original version. Got a brand new one off of E-bay a few months ago for $600. Image quality is just fine for what I use it for which is reviewing my driving etc.
I run the non-DL version. I'm a big fan; it is great for lap comparisons. The only issue is if you go to a track not in the database and you don't create it before you'll need to physically walk onto the start/finish line or be allowed to stop the car on it for a second to create the track. I've never bothered to use the software to create the track. On Saturday I just walked out to the start/finish prior to the track going hot.
I like my regular one. It works, not too expensive, allows me to do overlay, and is a high-quality unit with a long-lasting battery. I would have preferred the DL version but it doesn't work with the C5 apparently.
I recommend it.
Make sure you download your data to PC regularly. Once, I did several days without taking the time to download the data and the earlier data was overwritten without warning, which really sucked.
I recommend it.
