New dba t3 rotors?
Old 05-11-2013, 11:54 PM
Mike.D
Mike.D's Avatar
Default New dba t3 rotors?
Anyone using these? Are they a good replacement from Oem? I track the z and the rotors are cracking bad.
Old 05-12-2013, 10:03 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Which DBA T3 variety are you talking about, the T3 4000 series single piece slotted or the T3 5000 series 2 piece ?? I have used both on my Z06. The 4000 series has much better metalurgy (sp) than the cheap Chinese crap rotors available from the parts stores. I got maybe another 30% life out of them before they cracked. Last year I switched to the DBA 5000 series 2 piece units. These are pricy, but last MUCH longer ! I have 8 weekends (50 sessions) so far on this set of rings, they show a lot of surface checking but are still going strong. What it really amounts to is how bad do you hate changing rotors ? 4000 series you are going to change out more frequently but cost less. 5000 series last a lot longer but are pricy ---
Brake cooling is VERY important to rotor life - if you don't have it add now ! There are several vendors that sell the 5000 series at a good discount off list - KNS brakes in NC has the best prices I have found.
Old 05-22-2013, 07:23 PM
Mike.D
Mike.D's Avatar
I was looking at The 4000 series.
Old 05-24-2013, 05:22 PM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
For near the same price you may want to check these out. http://shop.performanceafx.com/C6-Z06_c14.htm
+1 for brake cooling.
Old 05-24-2013, 06:14 PM
drivinhard
drivinhard's Avatar
The 5000 are .100" thicker on the rotor walls (smaller air gap) than any of the other rotors (AP T1, Wilwood Spec37, Coleman, etc). All of them are around .300-.320 and the DBA are .410".
Old 05-24-2013, 08:36 PM
2MCHPWR
2MCHPWR's Avatar
is that good or bad?
Old 05-25-2013, 12:32 AM
Mike.D
Mike.D's Avatar
There's 10 rotors there, which are you recommending? I have cooling ducts if that's what you're referring too.
Old 05-25-2013, 03:15 AM
Dirty Howie
Dirty Howie's Avatar
I agree
And they are sponsors of our Corvette Challenge
DH
Old 05-25-2013, 08:30 AM
Gering
Tolero Apto Victum
Gering's Avatar
I like the flat face "non drilled or slotted". http://shop.performanceafx.com/C6-Fr...100166-167.htm You can give them a call and they can give you more detail on them, such as the rear rotors with or with out the parking brake, Performance AFX has great customer service as well.
Old 05-25-2013, 08:51 AM
2MCHPWR
2MCHPWR's Avatar
I already have 2 sets of the DBA 5000 hats. Do the DBA hats work with any other brands rings?
Old 05-25-2013, 11:42 AM
CHJ In Virginia
The number, size of bolt and radial spacing are unique to the DBA rotors. Don't think that any other company's rings will fit their hats.
Let me know if you want to get rid of one set of hats, I would be interested.
Old 05-26-2013, 09:18 PM
Mike.D
Mike.D's Avatar
Flat face? That goes against everything that I've been told and read about racing rotors.. Why?
Old 05-26-2013, 11:35 PM
Gering
Tolero Apto Victum
Gering's Avatar
Sir,
Here are some threads that may answer your question.
http://forums.corvetteforum.com/c6-c...l-or-hype.html
http://forums.corvetteforum.com/auto...ocrossing.html
http://forums.corvetteforum.com/c5-t...neer-test.html
http://forums.corvetteforum.com/auto...e-learned.html
http://www.digitalcorvettes.com/foru...ad.php?t=80144
Old 05-26-2013, 11:41 PM
spekterg35
spekterg35's Avatar
Thanks for the info, i just ordered a set of 5000s for the front and 4000s for the rear. W/HP Plus and str600 fluid. And stainless lines. Well see how much difference it makes.
Old 05-27-2013, 01:26 AM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
We found the DBA rotors to be more durable and more consistent than typical replacement rotors.
So much so we had DBA make us blanks.
http://forums.nasioc.com/forums/show....php?t=2504252
Corvette ones are next.
-Ken
Old 05-27-2013, 03:29 AM
Dirty Howie
-Ken
Ken
When will they be ready?
What is your opinion on pad wear of drilled vs slotted vs blank ??
And thanks again for sponsoring the Corvette Challenge
DH
Old 05-27-2013, 12:40 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
I am waiting for a quote w/ timing but at least 3-4 months from order.
I need to sell some of what I have first.
-Ken
To New dba t3 rotors?
Old 05-27-2013, 12:44 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
DH
I would assume pad wear increases but given it's still used in high level racing I would assume the benefits are worth it.
I would not expect too much difference in various types of machined rotors unless the machining was poor.
Old 05-28-2013, 10:57 AM
Gering
Tolero Apto Victum
Gering's Avatar
http://forums.corvetteforum.com/auto...ad-wear-2.html
Check out post #25.
Old 05-29-2013, 07:17 PM
Mike.D
Mike.D's Avatar
Good info there thanks.
Quick Reply: New dba t3 rotors?
