Adjusting Brake Booster
Old 05-12-2013, 07:04 PM
avizandum
avizandum's Avatar
Default Adjusting Brake Booster
Can the rod that pushes the master cylinder be adjusted to take travel out of the pedal?
(I had a Mustang that did, and it was a common AutoX Tracking tweak.)
Old 05-12-2013, 08:04 PM
moespeeds
moespeeds's Avatar
And to add another question, what happens if you eliminate the booster altogether? Rock solid pedal?
Old 05-12-2013, 11:19 PM
trackboss
trackboss's Avatar
If you eliminate the booster you will need to modify the brake pedal/mount to increase the leverage otherwise it will be really hard to actuate the brakes.
Old 05-13-2013, 12:43 PM
avizandum
avizandum's Avatar
Looking for actual responses to OP. Thanks.
To Adjusting Brake Booster
Quick Reply: Adjusting Brake Booster
