Bedding New Brake Pads Necessary?
If new brake pads are installed that are the same material as the used up pads and the rotors are reused, is there any benefit to bedding the new pads? The brake pad material is already on the rotors. Any thoughts?
YES!!! To eliminate "green fade" among other reasons.
http://www.stoptech.com/technical-su...-system-bed-in
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
I learned my lesson when a fellow that was running with me on the track came up to me and said, "Hey, you know your brakes are smoking like they are on fire." I took a look at my glazed over rotor and realized that was why the brake pedal had a weird feel. I now make sure I do a break in on all pads no matter the previous. I also switched to a better pad.
I have done it both ways over the years - properly bedding in new pads or rotors VS. just slapping new ones on and running the next session. Never noticed any difference in performance or longevity, either way. IMHO if you are not pushing to the absolute limit racing, don't waste your time.
We must agree to disagree.
The ONE time I went out without bedding I almost immediately glazed the pads & smeared the rotors.
The braking was OK but I think would have been better had I done a bed in.
Why does this seem to be a waste of time question to me???
It takes about five minutes of your time.
It allows you to have an excuse to run up to 80 and slam on the brakes a few times.
It does NO harm to the brake pads or rotors.
As long as even one brake expert (like Stop Tech) says it is beneficial,,, why not?
I want to know how to bed my race car. I'm just waiting for someone to call the cops on me cause how loud it is. I can't really bed on track because I can't let them cool adequately and braking at odd times is not safe for other drivers.
I hate good Samaritans. Get a life and stop ruining other peoples.
Seriously though, this was posted in the Autocrossing/Roadracing section where the majority of readers aren't using automatic convertibles as daily drivers (not that there's anything wrong with that). Many here have dedicated track cars that are loud, on slicks and not very street friendly or even street legal. Combine that with the fact that not everyone has immediate access to a highway nearby and you can see that the investment of time to bed your pads properly may take considerably longer than 5 minutes and carry a certain degree of risk.
Supporting Vendor
St. Jude Donor '11,'13
Always bed your pads or just by Carbotech pads and we pre bed them so you don't loose a session or risk your A** on the street.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Sr.Random input generator
It is very hard to bed in race pads on public streets. They make noise, and more importantly, they do need more speed and a much longer procedure to come up to fading heat. I could never find a road here that I can do so without getting caught by the 'good Samaritans'.
Doing it at the track is also very cumbersome, and usually costs you a good session, too. I usually take it easy on the brakes in the first few laps, one cool-down lap, and then get back at it. So far I've never had issues..
IMO, break them in on the street or don't break them in at all. I buy mine pre-bed anymore from Carbotech and just slap them on. I've never noticed a difference really.
Supporting Vendor
No, all Carbotech race compounds need proper bedding, that why we offer a pre bed program. If you have used our pads on the current rotor they still need to be bed. You may be referring to that all our compounds are compatible with each other which means when you get a fresh set you do not need to remove the old pad material from the rotor.
Supporting Vendor
I actually have found the track a difficult place not only to warm up my car but also break in my pads. I'm an instructor, so I miss warm-up so my first session is a hot advanced session. Trying to go out and get up to 80 and then brake down to 30 when people are flying up on at you at 100+ is dangerous IMO. Not only that, you get to the corners and you want to go slow but people are flying up on you. If there is more than one car even with pointbys you are holding them up because they may not see the pointby's at the speed differences.
