AP racing brakes or Wilwood
Looking to upgrade the brakes on my supercharged c5 z06. Considering AP racing or Wilwood. I'd like to hear about peoples experiences good and bad with each. Thanks
I still have the stockers as well and spend a weekend at the track about every month. From what I can tell, and from what I picked up from the other guys around the track, the only major benefit from either is less pad taper. If you spend an hour and flip your pads 1/3 through the wear cycle with stock, you're just as good but with $2,500 more in your pocket. If you want better brake performance, you need a bigger rotor which = 18s in the front and a bigger brake kit. That said, the couple guys I asked that are track mechanics recommend AP over the Willwood.
The OP mentioned a supercharger. Unless he has an amazing cooling system, I doubt that he ever spends more than 25 min at a time on the track. I don't, even with NA and an awesome cooling system. These are sports cars, but not race cars.
OP - if you are looking for an upgrade in appearance, pick the one that matches best. If you are looking for better performance, put up the cash for new front wheels, tires and a big brake kit. If you are pushing your current brakes close to the edge (like me) look into better pads first (e.g., Carbotech bobcats for the street or XP10s for the track). Other effective upgrades that are more cost effective include the DRM brake ducts, quantum spindles, Motul 600 fluid, new brake lines (might as well go SS while you are there) and hardbrakes titanium heat shields.
AP>Wilwood. I've used both on different cars over 12 years or so of racing. IMO AP are stronger, flex less and are better on track. Wilwood are probably OK as a street caliper but I would never use them again for a racing application.
Former Vendor
There are today a wide variety of 'Wilwwod' kits.....from factory kits to a number of alternate manufactures using Wilwood components. Understanding the pros and cons of each can help prevent getting the wrong kit for the need. Review the options and make an informed decision.
Very hard on brakes here and ive used both, finally going Stoptech route. At the top of the heap only two are consistently called out as being capable of putting up with the abuse a Vette can dish out: Brembo and Stoptech.
Been using the Ap 6 piston on 14" rotors for the C5 Z since 2001.
Great brakes, only had to rebuild the calipers once so far.
Have ducting and spindle ducts.
I don't believe that AP calipers have dust boots on them so that means more wear and tear if they are on the street. Catch alot of crap and tear up the seals and pistons.
Wilwood makes calipers with dust boot seals (Dynapro I think) as well as ones without, so if you are going to be doing a lot of street driving I would go with the Wilwoods.
Or Brembo's as they have dust seals as well.
I had Wilwood SL6Rs on my C4 and Hardbar's AP T1 setup currently on my C5Z. Both have spindle ducts, etc.
I beat the sh*t out of the C4 with the Wilwoods over a span of a couple of years and they never let me down. I have only spent a little bit of time on the APs, but there is something about them that just feels... better. Granted, that could very well be in large part due to the C4/C5 as a whole. The fit and finish of the APs seems to be a little better as well.
My personal evaluation as a weekend warrior (not a full time racer) is that Wilwood is good... AP is better. Either option is a definite upgrade over stock.
The stock calipers suck and the pads are very thin.
Read this.
https://www.corvetteforum.com/autocr...ease-read.html
