Calipers leaking???
Old 05-24-2013, 10:02 PM
trapp
trapp's Avatar
Default Calipers leaking???
I noticed that my calipers are leaking brake fluid...not from the brake line or the bleeder....so I think the seals are leaking.....
Anyone know of a rebuild kit for C6 GrandSport/Z06 brakes???
Tom
Old 05-24-2013, 10:44 PM
olbear1962
olbear1962's Avatar
I purchased Carlson seals for my C6 Z06 / GS calipers part no. 41290 Front pr; 41291 Rear pr
Purchased from the famous auction site.
Old 05-25-2013, 10:06 AM
trapp
trapp's Avatar
Do I need to replace pistons too? or just seals...
Old 05-25-2013, 11:13 AM
taken19
Track Junky
taken19's Avatar
The seals only should do the trick. When you rebuild, take note of any scoring in the pistons and/or bores. If they leak after new o-rings, then you can chase other options.
To Calipers leaking???
Quick Reply: Calipers leaking???
