Thread length on stock C6Z rear tie rods?
Does anyone know how many threads (linear count) are on the stock C6Z rear tie rods (outer end, of course)?
Reason I'm asking is I had to dial them out quite a lot to get 1/8 toe after installing new suspension components.
I have 16 threads exposed from the jam nut to where the threads stop on the rod. I just want to make sure I've not left it with a "tenuous grasp" on the outer thread!
(Yes.. I stupidly didn't disassemble and count myself when I had everything apart... duh.)
I don't know but on c5z I have gone 1/2 inch total toe in with no issue. I know of a couple of guys that went beyond that.
The rod ends stayed secure.
I think they usually thread in about an inch or a little more at stock alignment settings.
So a small toe change is only 2-3 threads.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Edit: Was out under the car doing some exhaust work and I noticed I had "2 1/4" thread" written in soapstone on the lift rail. I did a bunch of shear calculations to make sure I wasn't going to run into any issues when I unthreaded the ends to make the links longer. According to the calculations if you have more than about a half inch of threads in the link you should be okay. I would be very surprised if you had to adjust yours as far out as I had to adjust mine.
One side has 11 exposed threads, and the other has 12 - it's been running like that for many thousands of track miles with no problem.
It looks to me like 4 or 5 threads is about 1/4".
I would think that you are perfectly OK with 16 threads showing, but that's just MHO without knowing the total #.
Bob
