Aim Solo DL with Corvette ZR1
Which setting should I use? I see under the GM manufacturer selection, I have the LS2 and LS7 set-up. I'm guessing both of them probably work, but it'd be nice if AIM did one for the LS9, so I could get boost psi monitoring for the blower. Any help would be appreciated.
There is an oil temp and gear channel on the LS2 that isn't on the LS7. I've run both on my LS2 and didn't see any other differences.
