Caliper pin dust cover needed?
Old 05-27-2013, 05:53 PM
SunnydayDILYSI
SunnydayDILYSI's Avatar
Default Caliper pin dust cover needed?
I lost 25% of one this past weekend at the track. I guess it melted ? Is it highly recommended to keep these in good shape? Anyone know the part number?
Thanks,
Chris
Old 05-27-2013, 06:21 PM
c4cruiser
c4cruiser's Avatar
The boot keeps gunk from entering the hole in the abutment bracket where the caliper pin slides and keeps the grease in.
The boot covers are a generic type for many GM calipers; both Corvette and non-Corvette applications. Try p/n 12530703 (kit) or 12530706 (boot only).
Old 05-27-2013, 06:40 PM
froggy47
froggy47's Avatar
I always ck & replace those, napa probably has them. I don't replace the piston boot any more.
They hold up somewhat longer than the piston one.
Old 05-28-2013, 01:11 PM
CHJ In Virginia
CHJ In Virginia's Avatar
You really do need to keep a good set of rubber boots on the slider pins. If gone, it will allow dust and grit to get into the lubricant causing a possible frozen slider. Frozen slider = badly tapered pads = waste of $. They are cheap and easy to replace.
To Caliper pin dust cover needed?
Quick Reply: Caliper pin dust cover needed?
