Where are you buying brake bleed screws (c6z)
I just use the stock GM replacements. GM# 88957158 for the valve and GM# 14089150 for the cap. Replacement caps are one piece (the rubber valve seal and the dust cap are connected) vs. the factory 2-pc. arrangement. I recommend replacing the seal/cap when you're swapping out the valve.
