New Hubs: My Imagination ??
Old 06-09-2013, 11:46 PM
Dirty Howie
Dirty Howie's Avatar
Default New Hubs: My Imagination ??
So I had a rear hub go out a month back and had it replaced. Thought my car was more stable on the the freeway. This Friday I had the other 3 replaced and the car feels even more stable and quieter. Plus it seems to hold better going around corner. Haven't had it on the track yet.
The hubs had almost 130K and about 60 track days. My mechanic said one the three was definitely dry and it was good that I decided to replace them all.
So would you expect to FEEL and actual difference in handling with new hubs ???
PS: got Timkins at 20% off normal Autozone prices.
DH
Old 06-10-2013, 01:00 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
I believe you would feel the difference. The hubs go bad slowly and you get used to the sloppy handling then when your replace all 4 at once you are making a drastic change that can be felt.
Bill
Old 06-10-2013, 09:18 AM
CHJ In Virginia
CHJ In Virginia's Avatar
At 130K miles with that many track days on them, the hubs were toast. New ones should make a very noticeable difference. The general feel and steering response will be much better.
Old 06-10-2013, 01:07 PM
sperkins
sperkins's Avatar
I had 11yr old hubs on my car when I bought it and never had a problem and never noticed a difference when I swapped them out.
I can’t imagine that you’d be able to feel a difference changing them just to change them.
A hub bearing is either good or bad. There is no in between as far as I know.
Old 06-10-2013, 04:44 PM
Dirty Howie
Bill
I could feel the sloppiness mostly when cruising on the freeway.
DH
Old 06-10-2013, 04:45 PM
Dirty Howie
Steering does feel more responsive. Again cruising on freeway a little jiggle of the steering wheel now makes the car move.
DH
Old 06-10-2013, 04:47 PM
Dirty Howie
Alright, I'm going to ignore this since it would have to then be my imagination
DH
Old 06-10-2013, 05:22 PM
froggy47
froggy47's Avatar
Depends on how finely your butt-o-meter is calibrated, but to an extent I think you might feel it especially when you chg all 4.
Any alignment? Tire pressures chged? Sometimes you just want it to feel better because you spent the $$$ on it.
With all the opinion that skf is better, why Timkin? Just a price point?
Old 06-10-2013, 07:41 PM
Dirty Howie
Same tires, pressure and alignment.
Great price and hopefully they will perform as well as the original set
DH
To New Hubs: My Imagination ??
Quick Reply: New Hubs: My Imagination ??
