Installing DRM Rack bushing - Help
Old 06-10-2013, 11:08 AM
el es tu
el es tu's Avatar
Default Installing DRM Rack bushing - Help
I was installing the aluminum bushing into a new rack (off the car) and heard a clinking sound when lightly tapping the metal bushing parts in with a rubber mallet. I am not familiar with how steering racks are internally, but would like to know if this potentially could have caused a screw up to the rack or if the rack could have been messed up allowing for that clinking to occur (this a remanufactured rack that I am replacing my current one with).
As always thank you!
Old 06-10-2013, 01:33 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
If you screwed up a rack installing a our bushing there is something wrong with the rack. Try to figure out where the sound is coming from.
Randy
Old 06-10-2013, 01:36 PM
froggy47
froggy47's Avatar
Steering racks are pretty solid parts. You probably did not do any damage. I have a video on pulling a rack that might help you. Link in my sig below. Search my channel.
Old 06-10-2013, 03:46 PM
el es tu
el es tu's Avatar
The bushing was installed into the new rack without any issues (other than the noise) but I just wanted to be sure that the clinking coming from inside wasnt a sign of a messed up part.
Im just paranoid because the original rack was making a clacking noise on any hard steering inputs and I will go nuts if this replacement doesnt work.
Randy - I couldnt tell exactly where the noise was coming from in the rack and I didnt want to keep hitting it with the mallet to find out. The noise had nothing to do with your product but rather the method I used to install it, or possibly the condition of the "new" steering rack.
Old 06-10-2013, 04:23 PM
froggy47
froggy47's Avatar
There should not be any clink, clank or other noise that comes from a proper functioning rack.
Old 06-10-2013, 09:56 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Could have been a bell effect in the rack tube? Don't have to hit a bell very hard to make a big sound.
Randy
To Installing DRM Rack bushing - Help
Quick Reply: Installing DRM Rack bushing - Help
