APR GTC 500 mounting question
Old 06-11-2013, 09:32 PM
MarkDFW
MarkDFW's Avatar
Default APR GTC 500 mounting question
So I'm looking at this as well as a splitter for my next mod. After reading various threads, mounting the wing to the frame seems to be safer and more effective. How easy/hard is it to get in the hatch if you mount it to the frame? The obvious benefit to mounting to the hatch is cheaper cost and I assume easier hatch access.
Curious to see pics if any of you mounted to the frame and can easily open hatch? I daily drive my car for now so getting in hatch without hassle is important. Then again, not having the wing fly off and also having downforce on the frame is also important
Old 06-11-2013, 09:40 PM
1ED1
1ED1's Avatar
I have never heard of one coming off of a corvette. Mine is over 3 years old with lots of track time and no problems.
Old 06-11-2013, 10:28 PM
MarkDFW
MarkDFW's Avatar
I ran a search and quite a few stories of issues with wing mounted to frame. Those are the exception, not the rule.
Old 06-12-2013, 12:24 AM
Mike.D
Mike.D's Avatar
I'm interested in seeing some pics as well. Mark, I like the wing and want one too, but do you really want to drive around with that enormous wing every day?
Old 06-12-2013, 07:53 AM
MarkDFW
MarkDFW's Avatar
No. But I like going faster on the track, so I may have to suck it up and roll around in a hooptie ride.
Old 06-12-2013, 08:28 AM
JDIllon
JDIllon's Avatar
Mark, I have been running the APR mounted to the deck lid for 5 years and no problems. Here are some pictures. You will need to support the deck lid when it is open because the wing is to heavy for the support on the deck. But other than that, the wing works great. JD
[IMG][/IMG]
Old 06-12-2013, 11:54 AM
Lawdogg
Lawdogg's Avatar
Mine is deck lid mounted and has been over 170 mph a number of times. So far so good. As JDIllion said, the wing adds too much weight for the hatch struts so you have to hold the deck lid up when putting stuff in the back.
Old 06-12-2013, 12:23 PM
MarkDFW
MarkDFW's Avatar
Have either of you had any issues with the wing causing the hatch to deform at all? I have a buddy with a Mustang that has run NASA TT for a number of years and his trunk lid is deformed quite a bit from the downforce.
Old 06-12-2013, 01:16 PM
JDIllon
JDIllon's Avatar
Nope not on mine! 165+ many times and no problems. No cracks! I made a neat deal to keep the deck lid up. I cut a piece of hard plastic pipe just the right length and then split it down the length with a 1/4" cut and I slip that over the strut to hold the deck lid up. JD
Old 06-12-2013, 08:09 PM
Mike.D
Mike.D's Avatar
[IMG][/IMG]
looks awesome!
don't want to hijack, but how is your car lowered?
Hope not on mine! 165+ many times and no problems. No cracks! I made a neat deal to keep the deck lid up. I cut a piece of hard plastic pipe just the right length and then split it down the length with a 1/4" cut and I slip that over the strut to hold the deck lid up. JD
smart idea
Old 06-13-2013, 12:02 AM
Lawdogg
Lawdogg's Avatar
LG coilovers.
Old 06-13-2013, 12:03 AM
Lawdogg
Lawdogg's Avatar
Beats my cut off mop.
Old 06-13-2013, 09:56 AM
dvandentop
dvandentop's Avatar
beats my scrap lumber LOL
Old 06-13-2013, 09:12 PM
MarkDFW
MarkDFW's Avatar
Very good idea.
I guess almost no one is mounting this wing to the frame, which is surprising. Glad you guys aren't having any issues.
Old 06-15-2013, 07:13 AM
timd38
timd38's Avatar
How does it mount? I looked on the APR site, but they don't tell you.
Do you have to drill holes in the deck lid?
Thanks!
Old 06-15-2013, 06:54 PM
Lawdogg
Lawdogg's Avatar
Yes. Nothing that can't be fixed at a body shop if you want to return to stock.
Old 06-16-2013, 11:17 AM
geerookie
geerookie's Avatar
You guys should look at the GTC300. It has better downforce numbers at the speeds normally seen in DE or our level of racing and also has a better L/D ratio even though it isn't as wide. Bonus, it costs less
Old 07-16-2013, 09:58 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Anyone have pics of how the braces are underneath? I went ahead and mounted mine up seeing I had some free time, but don't have a splitter yet.
[IMG][/IMG]
I bought a used deck for $100 so I wouldn't have to drill my good one. It is only 4 bolts to switch out deck lid, so it will not be much different than switching out racing seats. Just not sure about the mounting brackets underneath.
Old 07-16-2013, 04:42 PM
froggy47
froggy47's Avatar
[IMG][/IMG]
That's what I would do, used deck off a wreck.
To APR GTC 500 mounting question
Quick Reply: APR GTC 500 mounting question
