C6 GS vs C5Z: better handling & reliability?
Last week there was an interesting thread regarding C5Z vs C6 Z51. I think this topic had come up many times before, but this time there was a lot of opinion that the C6 z51 in stock trim didn't handle nearly as well as the C5Z and also had some nasty reliability issues (the engine, and I think the diff etc). In particular, there was vid showing the C6 Z51 going into somewhat unpredicted oversteer after hard braking.
So my question: Does the C6 GS still have this same oversteer characteristic which the C5Z does not? Which is the better handling car?
The dry sump of the C6 gS should fix the LS3 oilling issues, but what about the diff, etc?
Above are not serious, immediate need questions but I find it a very intersting topic in that I see the C6 GS as a likely upgrade at some point to my street C5Z that sees a few track days per year. Most of what attacted me to the C5Z is its proven track prowess and in particular its praised handling characteristics.
Thanks,
Andy
Thanks,
Andy
Thanks,
Andy
Thanks,
Andy
Has it? Does the stock GS suspension still have the oversteer?
GS would be the way to go now IMO. The C5Z is a great car, but all the parts are obsolete including the engines. GM no longer carries most of them. Grandsports can be made to handle however you like with simple mods plus they come with factory coolers, dry sumps, and wide tires.
C5Z can have wide tires and AP racing brakes for relatively little money in the grand scheme of the cost of a track car. However, upgrading suspension (to fix the oversteer) and replacing diff or axle parts repeatedly would be a pain. Plus I'm not sure if LS3 w/GM dry sump has actually proven reliable in the last 3 years.
Yeah, first time I've heard of rear diff issues. I never had an issue with my '08 Z51. I added the extra quart of oil, pads, tires, and brake fluid and pounded the car for 3 years on track with no problems.
The C5 Z is a sweet ride, but at this point, I would think the GS with the LS3 dry sump and the Z06 goodies would be the way to go. Plus, it should have a warranty.
I love my C5Z... but would prefer a C6 GS.
As others have noted: stronger powertrain, dry sump, bigger tires/brakes. Any supposed balance issues can usually be dealt with pretty easily with adjustable sway bars and a proper alignment, both of which are fairly cheap.
The only C6 that has differential issues is the 2005 due to the bad design of the mounts.
As for oversteer, that's a new one. I know that my C6 had some oversteer when cornering hard on a bumpy surface as the rear shocks could not maintain traction. That was fixed with Callaway/Eibach shocks. Any good aftermarket shock with good valving should fix that issue.
What I mean is that GM is no longer manufacturing many (or most) parts for the C5. You have to find used or remanufactured parts.
Does anyone have back to back experience? I think this a great topic, just leave price out of it. I see a lot of satisfied customers on both sides here.
Steering rack is a big one. Also the earlier C5s have some computer modules that are no longer available. It will only get worse as the cars get older.
Even when I had my '00 7 years, key fobs were much less expensive for 01+ than the earlier ones.
I had a 2008 c6 base and then got a 99 frc. I pulled the pfadt shocks and swaybars from the c6 and put them on the frc. The frc did have the carpet removed and lighter seats when I got it (it was a track school car). It is difficult to compare since I've improved as a driver but 2 cents.... I will say I love the c5 (I've now taken about 250 lbs or more out of it and done some other things). I miss the motor of the ls3.
The c5 feels like a smaller car to me and seems to rotate easier (factually it is a bigger car). This could be car to car variation or just bad memory on my part or ghosts in the c6 code that never truly lets the car 100% free of electric nannies . The ls3 pulls like a hoss compared to the ls1 but my ls1 has 91k miles and 7k of those are track miles and has never been refreshed to my knowledge.
I'm very happy with my choice but I was not happy at the (un)expected costs I ran into getting a 12 year old car track worthy. Steering rack, front main seal, torque tube bushings...
I don't recall seeing any issues with the GS motors (plenty of debate on the LS3 w/o dry sump). I do feel like the C5 rotates easier. I do think getting newer typically means less surprises once you start tracking. My youtube channel has the two cars running on the same tracks. http://www.youtube.com/user/awlittle13?feature=guide
Received 8,928 Likes
Bill
I would stick with the C5 Z. Everything I've read says the LS6 is pretty much the most reliable track motor that has been in a Z. Hard to beat that if you're on a budget, even if parts are getting harder to find.
