What is the GM spec for oil pressure @ temp?
Old 06-19-2013, 02:50 PM
TKOGTO
TKOGTO's Avatar
Default What is the GM spec for oil pressure @ temp?
2010 A6 GS, LS3, M1 5w 30.
I've read about the 10psi/1k rpm guideline that is generally used. Also heard spec is lower for higher temps (presumably above 212F) but did not find the data for any temp.
Old 06-19-2013, 06:53 PM
naschmitz
naschmitz's Avatar
At the oil temps I run (270 to 280-F) I use Mobil 1 0W40 to get higher oil pressure at high load & RPM. 2006 M6 LS2
Lots of videos with oil temp, pressure, and RPM logged here:
Old 06-19-2013, 07:43 PM
crimlwC6
crimlwC6's Avatar
Sorry to high Jack but what system are you using to log oil pressure and temp?
Old 06-19-2013, 08:44 PM
naschmitz
naschmitz's Avatar
Aim Solo DL connected to OBDII port and RaceRender 2 for video production
Old 06-27-2013, 01:32 PM
TKOGTO
TKOGTO's Avatar
Tto
To What is the GM spec for oil pressure @ temp?
Quick Reply: What is the GM spec for oil pressure @ temp?
