APR studs with SKF bearings
Old 07-03-2013, 11:58 AM
TKOGTO
TKOGTO's Avatar
Default APR studs with SKF bearings
Are the studs a recommended upgrade when going with the bearings?
Car is dual purpose but I see R-compounds in the near future.
Old 07-03-2013, 12:06 PM
brkntrxn
brkntrxn's Avatar
Yes.
Old 07-03-2013, 12:46 PM
froggy47
froggy47's Avatar
Old 07-03-2013, 01:14 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
If you try different wheels in the future you may find a spacer is needed, also. You will be glad you upgraded to the longer studs. There are many good reasons to go ARP.
Old 07-03-2013, 01:20 PM
el es tu
el es tu's Avatar
I may need to replace my wheel bearings due to a clicking noise I keep getting on high load turns - does anyone know who has the lowest cost on these with the arp studs installed into the units?
thanks!
Old 07-03-2013, 01:47 PM
crease-guard
crease-guard's Avatar
I got mine from Gary at Hardbar. Seemed to have the best price with shipping.
Old 07-03-2013, 03:35 PM
JDIllon
JDIllon's Avatar
What is the stud size for a C6-Z06 or what ARP studs should be used for the SKFs on a C6-Z06? thanks, JD
Old 07-03-2013, 08:03 PM
CHJ In Virginia
CHJ In Virginia's Avatar
ABSOLUTELY !! If you are going to the expense of installing the SKF hubs, you should install the ARP studs as well. Not that much more $ but the peace of mind is priceless. If you have ever broken a stud, you will know what I mean. The ARP are longer so you can use a spacer in the future if necessary for a BBK or bifferent wheels. I pressed the studs in myself so I can't tell you who has the least expensive combo for sale - Check Hardbar and Phoenix.
Old 07-04-2013, 10:21 PM
phipp85
phipp85's Avatar
100-7708 is the ARP part number for a 2.5" stud
100-7713 for the 3.25" stud
Here is a link to the 2.5" studs from JEGS with free shipping.
http://www.jegs.com/webapp/wcs/store...hTerm=100-7708
I use the 2.5" studs on my C6Z06 with open ended steel lug nuts from NAPA (napa part number is 641-2141).
Old 07-05-2013, 08:49 AM
JDIllon
JDIllon's Avatar
THANKS for the info!!!! Did you install them while the hubs were on the car?? JD
Old 07-05-2013, 10:30 AM
phipp85
phipp85's Avatar
Unfortunately no, all four hubs had to come out. I removed the upper control arm and the steering knuckle as one piece and did the rest on the bench. You can get the stock studs out on the car but you can't get the longer ARP ones in. It turned out to be a bigger job than expected.
Old 07-05-2013, 06:55 PM
72Vega
72Vega's Avatar
with all that has been said.
Some other reasons to replace OEM with ARP studs -- especially if you drive your car to events and change to track tires -- they stand up much better to the many, many times we mount, demount and torque track and street tires. Also, if you use open lug nuts you can tell at a glance as you do a pre-session car walk around if you forgot to torque one.
Old 07-06-2013, 11:42 PM
Gering
Tolero Apto Victum
Gering's Avatar
Old 07-07-2013, 02:16 PM
froggy47
froggy47's Avatar
Originally Posted by Gering
Here is a video of me installing front arp studs WITHOUT removing the bearing
I also have a video of the rear WITH bearing removal. WITHOUT removal (rear) is possible only by drilling the backing plate.
Check link below for more Vette diy videos.
Old 07-07-2013, 11:43 PM
Supercharged111
Supercharged111's Avatar
How about open ended lug nut recommendations? I ASSume the longer studs require them.
Old 07-07-2013, 11:52 PM
phipp85
phipp85's Avatar
Open ended steel lug nuts from NAPA is what I use. Couldn't use the stock ones because they would bottom out on my car. Part number is 641-2141.
Old 07-08-2013, 12:44 AM
Gering
Tolero Apto Victum
Gering's Avatar
froggy47: Thank You Sir!
To APR studs with SKF bearings
Old 07-08-2013, 10:21 AM
geerookie
geerookie's Avatar
Here's the ones I use.
http://bigwheelsnyc.com/rvm635-22x85...2-1-4-1-2.aspx
$25 for 20 They have more thread engagment than a standard lugnut due to being ET style.
Old 07-08-2013, 11:52 AM
froggy47
froggy47's Avatar
I use those also, I toss them every year or so & get new ones.
Old 07-08-2013, 01:14 PM
el es tu
el es tu's Avatar
Are the arp still a 12x1.5 thread?
Also - has anyone else noticed that the napa oreilly and autozone websites all have the wrong lugnut sizes for our cars?
Quick Reply: APR studs with SKF bearings
