New Carbotech Track Compound - XP24
Old 07-03-2013, 03:19 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
Default Delete thread
Nothing Happened
Old 07-03-2013, 03:50 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
I was using XP24 at VIR last week in my '02 Z06 with the AP T1 kit. I have always liked the feel of Carbotech pads and that is still the case with the XP24. I burned up a set of XP20's pretty quickly early in the year but the XP24's seem to be wearing very well. Admittedly VIR with the long straights gives the brakes plenty of time to cool down so the wear rate isn't as high as it can be at other tracks, but it was a good beginning.
Old 07-03-2013, 04:22 PM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Originally Posted by KNSBrakes
Last week at the NCM - VIR event Danny Puskar from Carbotech came out to visit and he brought with him a few samples of the new XP24 compound.
We are waiting for more info but here's a brief summary of what he said.
The goal was to decrease the wear rate yet maintain the high friction and fade resistance of the other high end XP race compounds. We'll have to wait/see how that works out as they get used in the field.
Danny also mentioned that along the way these pads:
-Have the most linear friction curve he has seen.
-Are lighter than the other compounds
-Last longer on track
We garnered a couple sets from him - 1 for C6Z 1 piece fronts and 1 set Stoptech ST40 fronts.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 07-03-2013, 04:37 PM
JeremyGSU
JeremyGSU's Avatar
Good to hear. I burned almost half my XP20s away in a day at Sebring with my AP T1 kit. I'm hoping that once I make the switch I get the same results.
Old 07-03-2013, 05:18 PM
Z06Tracker
Z06Tracker's Avatar
Interesting. Let me know how you like them in the ST 40's.
Old 07-04-2013, 12:00 AM
Supercharged111
Supercharged111's Avatar
Where do they fit in with respect to friction/wear resistance/rotor life/modulation/etc compared to the existing compounds? Better than every pad in every way?
Old 07-04-2013, 08:30 AM
rfn026
rfn026's Avatar
Here's an article on brake pads that I did with the help of Carbotech.
Richard Newton
Facebook
Old 07-04-2013, 11:38 AM
blkbrd69
blkbrd69's Avatar
May try a pair soon.
Does not matter wheather I amon XP12, XP20, or XR2, I go through over 1/2-2/3 of the front pad lining in one weekend at Sebring.
Would really like a pad I can run 2 weekends without having to change pads on Saturday evening.
Willing to be a beta tester
Old 07-05-2013, 11:10 AM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
Nothing
Old 07-05-2013, 12:34 PM
JeremyGSU
JeremyGSU's Avatar
Do your pads wear evenly? I switched to the T1 setup just to avoid the pad taper. Wear rate is about the same -but less flipping and much cheaper pads alone was worth it.
I think Sebring might be tough. Always hot - and hard on brakes right?
I am still getting pad taper with my T1 kit at Sebring. However, switching the pads is very easy with one bolt.
Old 07-05-2013, 02:10 PM
taken19
Track Junky
taken19's Avatar
I've burned just about everything I've put on the track in the past couple years, even a set of proprietary pads from a forum vendor. If you're looking for a test pilot in South Florida, let me know.
I'm a long time fan of Carbotech!
Old 07-05-2013, 03:18 PM
skxf430
skxf430's Avatar
Will they have a pad to fit a Stoptech ST60?
Old 07-05-2013, 03:25 PM
KNSBrakes
Supporting Vendor
KNSBrakes's Avatar
Nothing
Old 07-06-2013, 11:18 AM
sebdavid
sebdavid's Avatar
Dammit I was about to put on the XP20s I got a few weeks back... I guess I'll try those next when they are available. Could Carbotech (Adam?) let us know when they are?
I also go through pads quickly and get taper with the T1 kit.
To New Carbotech Track Compound - XP24
Quick Reply: New Carbotech Track Compound - XP24
