c5 z06 nt-01 camber
c5 z06 nt-01 camber
Hi
I am running 315/30/18 and 275/40/17 nt01
Presently stock camber alignment. I am getting50% more wear on outside of front tires. Any advice on alignment /camber would be appreciated. I drive to the trackon the nt01's (150 miles). Track, Chuckwalla, ca
Thanks!
Thanks!
you need more negative camber, from what i have read -1.5 to -2.5 degrees in the front on a softer tire like the nto1. search is your friend. there are a few helpful stickies at the top of this section, which will explain it.
I run -1.7 front -1.1 rear with 275 square nt01. My tire temps are nice and even across the face at about 200 degrees. This is with Pfadt poly bushings and JOC stage one.
