bearing question C5Z
Old 07-08-2013, 08:54 AM
555ss
555ss's Avatar
Default bearing question C5Z
Just a question for those that have put in a set of new bearings in their LS6 and what bearings did you ues?
The CL77HK's (coated) that I allways use in my drag race engine say they are .001 oversize has that extra caused any issues for you? The car is a dedicated track car with a Katech preped LS6 oilpump not the high volume version..
Old 07-08-2013, 09:03 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Can't respond on those specific bearings. If Katech built the motor, I would sure call them for their recommendation.
Quick Reply: bearing question C5Z
