Will Z51 front rotor fit on my rear Z06?
Old 07-09-2013, 10:04 AM
erichg1000
erichg1000's Avatar
Default Will Z51 front rotor fit on my rear Z06?
http://www.corvetteguruforum.com/mod...?post_id=49303
The above thread mentions the Z51 fronts are 13.4 x 1.25
The Z06 rears are 13.4 x 1
Will the Z51s fit the rear on a Z06 (if my pads are already worn a bit?)
Old 07-09-2013, 10:39 AM
naschmitz
naschmitz's Avatar
Isn't the parking brake hat missing on the front rotors?
Old 07-09-2013, 10:45 AM
erichg1000
erichg1000's Avatar
Good point
Old 07-10-2013, 12:16 AM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
Yes, they will fit. Yes, you will have to lose your parking brake and about 5 lbs of cable and brackets.
Win/Win!
Old 07-10-2013, 10:39 AM
erichg1000
erichg1000's Avatar
well i don't use the parking brake much anyway. Will the Z51 front rotor fit over the the parking brake drum? (and then I just remember not to use the parking brake)?
Old 07-10-2013, 10:50 AM
naschmitz
naschmitz's Avatar
The only thing I use my parking brake for is to get the vehicle registered. Wish I could ditch it.
To Will Z51 front rotor fit on my rear Z06?
Quick Reply: Will Z51 front rotor fit on my rear Z06?
