C5 rear suspension question
Hey guys, I have only owned my Z06 for 4 months now and just got it on the track two weekends ago. I am a former 9 year Mustang guy and understood its suspension very well, but the Corvette suspension is a bit new to me. I realize it has anti-sway bars like the Mustangs, but how is the axle and springs all tied together? I haven't really had time to get up in there an look around too much yet. I do realize it doesn't have coil springs like a Mustang. A Mustang is also either a four link or three link system. Mine just had the four control arms, two upper and two lower. The lowers tied the axle to the torque boxes at the subframe and the uppers tied the axle to the upper frame. I also had a panhard bar to keep the axle from moving side to side. What keeps the Corvette axle planted under the frame? I have seen an older C4 get on it around a corner before and its butt was wagging side to side all over the top of the axle.
The best thing to do is to jack up the car and then jack under the outer ball joint and see how it all works.
The leaf spring is transverse and exerts force on the lower A-arms.
Received 8,915 Likes
Yes, it works just like a 19th century buggy spring but there isn't anything wrong with that. Vette has been using leaf springs since 1963. Although the C2s and C3s had front coil springs. Vette has one upper and one lower control arm on each side in the rear just like the front. Axle half shafts are held in place on each side by the knuckle that goes between the CAs and the diff. The diff, lower control arms and spring are all mounted to the rear cradle which is bolted to the frame. The upper control arms are mounted to the frame. The axles aren't going anywhere unless something breaks.
Bill
Bill
Bill
Bill
The cradle is bolted to the frame in 4 spots and pinned in 2. The leaf spring, sway bar, differential and lower control arms are bolted to the cradle. The upper control arms are bolted to the frame. It isn't going anywhere without a big whack.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Keep in mind the C4 rear suspension is substantially different than the C5. Sounds like that car was very worn out or had some extreme axle hop.
the diff doesn't float like it sort-of does in a C4. It is bolted solidly to the subframe, which is bolted directly to the frame. Everything connects to the lower a-arms (springs, shocks, sways), but work independently from there.
