SCCA T2 restrictor plate dyno numbers
Old 07-11-2013, 12:05 PM
zigspeed10
zigspeed10's Avatar
Default SCCA T2 restrictor plate dyno numbers
I am interested in what horsepower guys are making with a stock LS6 with headers running the 55mm restrictor plate.
I am actually racing in NASA ST3/ST2 and am looking for a way to easily switch between classes based on car counts by simply removing or adding the restrictor plate. I'm targeting around 330 hp with and 395 without. I want to know if anyone running a restrictor plate will share their dyno numbers.
Old 07-17-2013, 12:41 AM
CP Thunder
CP Thunder's Avatar
The 'target' for the restricted LS6 was 360 hp...........both with and without headers. Your 330 is low.
Old 07-17-2013, 05:43 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Stock LS6 with headers dynoed 320 RWHP at Putnam on the nasa dyno, without 367. I believe it was detuned in the first place also
Old 07-19-2013, 09:47 PM
zigspeed10
zigspeed10's Avatar
Went to the dyno today to try out the restrictor plate.
With 55mm restrictor plate and no detuning the car made 357.
With 55mm restrictor plate and detuning we got it down to 332.
With out restrictor plate and still with the detune it made 403.
For reference the engine is a stock LS6 with long tubes, open exhaust, custom intake.
Detuning was done via pulling the throttle percentages, the lowest percentage needed was I believe 78%. The car made more power than I wanted without the restrictor but I think I can ballast up for it.
So I should be able to successfully run ST3 or ST2 by pulling the restrictor plate and adding some ballast.
Old 07-19-2013, 10:12 PM
fatbillybob
fatbillybob's Avatar
How will you handle the aero? ST2 really is an aero class while st3 mixed and T2 no aero
Old 07-19-2013, 10:32 PM
zigspeed10
zigspeed10's Avatar
I will be running aero in ST3. At least I will try it and see if it's worth the pw/wt hit.
Old 07-20-2013, 12:49 PM
brkntrxn
brkntrxn's Avatar
Good information, David. Thanks a ton for sharing!
Old 07-20-2013, 12:50 PM
brkntrxn
brkntrxn's Avatar
How did the curves look with the restrictor in place? Still broad or more of a peak?
PM me if you prefer.
Old 07-20-2013, 01:32 PM
zigspeed10
zigspeed10's Avatar
Because we had to pull throttle percentages, we were able to make the 330hp curve pretty flat to the rev limiter. It hits 330hp about 500 rpm later than it would if we didn't use the restrictor so there's a slight disadvantage to the restrictor plate.
Without the restricter, the 400hp curve is not flat, it's not like stock either because of the way we pulled throttle percentages.
I will be giving up a lot to the big motors with flat curves in ST2, but at least when I run in that class I will have a fighting chance.
To SCCA T2 restrictor plate dyno numbers
Quick Reply: SCCA T2 restrictor plate dyno numbers
