Aluminum Flywheel Article
Old 07-27-2013, 07:59 AM
rfn026
rfn026's Avatar
Default Aluminum Flywheel Article
Here's a link to an article I did for Vette magazine back in 2005. It's about an aluminum flywheel. I still think it's the single best thing I ever did for the car when it comes to track days.
Richard Newton
Old 07-27-2013, 11:12 AM
Supercharged111
Supercharged111's Avatar
And just to back you up, here's some proof.
http://www.vetteweb.com/tech/0407vet...l_information/
Richard I couldn't find your article on the FB page, just a lot of retro race pics and people that are still alive to comment on them.
Old 07-27-2013, 02:50 PM
froggy47
froggy47's Avatar
I guess they had 3 or 4 guys working on the car to do it that fast.
Old 07-27-2013, 03:16 PM
FASTFATBOY
FASTFATBOY's Avatar
Originally Posted by rfn026
Here's a link to an article I did for Vette back in 2005. It's about an aluminum flywheel. I still think it's the single best thing I ever did for the car when it comes to track days.
Richard Newton
It only shows your Facebook page. Have a direct link?
Old 07-27-2013, 03:48 PM
rfn026
rfn026's Avatar
Sorry about that . Here's the correct link.
Richard Newton
Old 07-27-2013, 10:38 PM
hungryhippo
hungryhippo's Avatar
Interesting. I need to wear out my clutch faster so i can upgrade.
Old 07-28-2013, 01:39 PM
Supercharged111
When I did this to my AE111 Trueno (supercharged), my traction problems significantly worsened. It used to be that 1st was worthless, 2nd would dig, and 3rd would scratch on the upshift then be kind of OK. After the flywheel, 1 was impossibly worthless, 2nd was borderline worthless, and 3rd would dig and dart the car (FWD) all over the road. At first I thought it was the change in weather (suddenly cooler), but later came to realize it was my lighter clutch assembly. On a Corvette, you can get Spec's 10.5" unit that comes with aluminum flywheel AND PP and drops about 20# of mass. MOI remains similar to stock, Richard, I feel that's something that bears mentioning. If you keep a 50# clutch in there but make a it a small diameter multi-disc setup, it'll act the same as a larger diameter yet lighter weight clutch.
Old 07-28-2013, 03:24 PM
FASTFATBOY
FASTFATBOY's Avatar
I am looking to help the brakes on my 3800lb barge. I can manage the throttle application.
To Aluminum Flywheel Article
Quick Reply: Aluminum Flywheel Article
