Strange drivetrain noise
Old 07-27-2013, 04:58 PM
Charley Hoyt
Charley Hoyt's Avatar
Default Strange drivetrain noise
Recently I have been noticing a noise coming from my drivetrain. It is most noticeable in the lower gears but I can hear it in all gears. It almost sounds like a scraping or rubbing sound. It goes away when I enguage the clutch or if I put the car in neutral while driving and I let the clutch out. Any ideas what this could be? Throw out bearing? Synchros?
Thanks,
Charley
Old 07-28-2013, 11:20 AM
BossV8
BossV8's Avatar
Like this ?
Old 07-28-2013, 11:55 AM
dvandentop
dvandentop's Avatar
rear diff in vid it sounds like
Old 07-28-2013, 12:45 PM
BossV8
BossV8's Avatar
Yes but it's not. We changed it twice. Now we think tranny of torque tube.
Old 07-28-2013, 02:10 PM
dvandentop
dvandentop's Avatar
damn that will drive ya nuts then for sure
Old 07-28-2013, 02:14 PM
BossV8
BossV8's Avatar
One year. No track days ... Grrrrrrrrrrr
Old 07-28-2013, 02:23 PM
froggy47
froggy47's Avatar
WAG torque tube. How many miles, use?
Old 07-28-2013, 03:16 PM
msracing
msracing's Avatar
diff for sure.. if you notice it dosnt matter what gear you are it the whine is consistent with the over all wheel speed in your video ,,the other thing that shows me its the diff is that it only make the whine when you are under a load not when you are coasting... its the diff for sure
check you rear end gear lash .. on the ring and pinion or the ring and pinion have gone bad...
Old 07-28-2013, 03:26 PM
froggy47
froggy47's Avatar
Just to be clear, the OP posts a question.
Then Bossv8 finds a video & asks the OP if it sounds like this.
So the video is not, at this point, necessarily what the OP has.
We need the OP back to confirm or not if it sounds like that.
Old 07-28-2013, 03:32 PM
msracing
msracing's Avatar
sorry i thought it was a video of the OP car...
Old 07-28-2013, 03:45 PM
BossV8
BossV8's Avatar
My fault. I am sorry for the OP. I hijacked his post without wanting.
Old 07-28-2013, 06:30 PM
Charley Hoyt
No the sound mine is making is quieter than that. Also mine seems to varry by engine speed where yours seems to varry by vehicle speed. I tried videoing mine but the noise wasn't loud enough to be heard.
To Strange drivetrain noise
Quick Reply: Strange drivetrain noise
