C6Z- Is this too aggressive for 80% street?
Old 07-30-2013, 11:58 AM
wolf8218
wolf8218's Avatar
Default C6Z- Is this too aggressive for 80% street?
Hey guys,
Just got coilovers and an alignment. Michelin Pilot Super Sports 325 - R Nitto Invo 275 - F (Hey, they're still good!)
What can you tell me about this setup?
Old 07-30-2013, 12:33 PM
Scooter70
Scooter70's Avatar
Too aggressive? No.
I would want a little bit of toe-in in front and rear and less camber in the rear. See the Pfadt chart below.
http://www.pfadtracing.com/blog/wp-c...-9.12.2011.pdf
Old 07-30-2013, 12:40 PM
Lawdogg
Lawdogg's Avatar
I'm running -3.0 camber front and -1.6 rear. My car sees a lot of street use too. I agree that your rear camber is a little more than needed. Your front camber is light if you are running r compounds on the track
Old 07-30-2013, 12:48 PM
wolf8218
wolf8218's Avatar
I will be using street tires at the track (I only have one set of wheels)
Old 07-30-2013, 01:50 PM
Solofast
Solofast's Avatar
Rule of thumb is about a half a degree less in the back than in the front. With that much in the back you will have a good bit of wear on the insides. With your -1.6 in the front I'd be looking at more like -1.1 in the back.
The reason for that is that you lose negative camber when you turn the front wheels, due to kingpin inclination angle, and the back tires don't lose any since they don't steer.
I'd be cranking back some negative camber in the back since it isn't going to help handling, the car is going to push the way it is set up now anyway, so all you gain from more negative camber in the back is more inside tire wear.
Old 07-30-2013, 01:57 PM
95jersey
95jersey's Avatar
Umm, I think you got the alignment backwards. You have more camber in the rear than the front. It should be the other way around. If the numbers were backwards, it would be a nice street/track alignment for street tires.
Anything under -2.0 is not aggressive, but your running street tires so running -3.0 would be a waste as you won't get enough grip to take advantage of all that camber.
Old 07-30-2013, 02:17 PM
wolf8218
wolf8218's Avatar
Thanks for the tips guys.
I actually meant to take the pfadt specs to the alignment shop, but totally fogot! Doh!
Will try to dial back rear camber. Any thoughts on toe? all pfadt specs for dual and street use say no toe.
Old 07-30-2013, 03:24 PM
froggy47
froggy47's Avatar
What they all said, too much neg in the rear for what you have in front.
I run -3 front -1.6 rear for race/slicks.
Old 07-30-2013, 06:23 PM
ErnieN85
ErnieN85's Avatar
I'm running -.8 front on the street and pull shims to get -1.6 on track
i leave the rear alone at -1.1
Heinracy liked my set up at VIR and I'm using PSS also
To C6Z- Is this too aggressive for 80% street?
Quick Reply: C6Z- Is this too aggressive for 80% street?
