Dynojet information.....
When the Dynojet sheet is produced, part of the information shown in the Run Conditions is the temperature. Where is that temperature coming from? Is that the intake temperature read by the MAF sensor or is it the ambient temperature around the dyno?
Former Vendor
Temp sensor is in the stack.
The dynojet has a weather station to tell the software about the temperature, barometric pressure and humidity. It'll probably be hanging on the wall somewhere near the dyno itself.
Positioning of the weather station matters. The Thunderhill dyno's weather station is deep inside the tin shed so it reads 10F too high on sunny days, which I believe is why the readings are high
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Here is a rather lengthy explanation of 'SAE corrected' but you know most, if not all, of this already I'll bet. It does have a link for temperature, though.
http://www.land-and-sea.com/dyno-tec...horsepower.htm
