How do you protecting your paint during Autocross?
Some people say if you are too worried about damage to your car you shouldn't be doing track events, but I'd really like to explore the capabilities of my car. I made it through two days of a HPDE event at Watkins Glen last year with no issues. I'll be doing my first autocross event in a few weeks and I'll be shocked if I don't take out some cones in my first few laps. My 2003 Z06 is black so everything shows. The paint looks amazingly good for a 10 year old car, so I'd like to do whatever I can to keep it that way. There must be some way to reduce the odds of damage to the finish of my vehicle. I suppose a bra for the front might be an option. What are some other things people do to protect their street vehicles that also see track use?
Received 8,928 Likes
Depends on the cones used. Most leave little scuff marks that can easily be removed with a little polish. The cone leaves a small part of itself as an extra layer ontop of the paint. One group I know uses very old and very tall cones (24 to 30 inches) that have seen a lot of abuse and they have dirt ground into them from being dragged by a car. Hit one of those with a painted part of the car and you get scratches. Otherwise, a few minutes with some polish on a rag usually gets the scuff marks off.
Bill
Bill
Bill
Bill
Google it. Or check my YT channel I have a vid on putting racer tape on.
Max G’s
Bill
Bill
I just do the blue painter's tape protection for the high "road rash" areas, which for me are the mirrors and the rear brake ducts:
I concur with the opinions that the cones aren't your biggest worry. I've taken out a couple of cones, but the marks literally wiped right off (just a bit of elbow grease). I don't know if layers of Rejex helped or not, but there was absolutely no damage left after these hits:
What I found after a weekend at El Toro Airbase (Orange County, CA):
My rear bumper behind the rear tires is screwed thanks to rocks and A6s. If I had this car since new, I think I would have tried this stuff masked off. That way, unlike plastidip, it wouldn't look terrible between events and just reapply maybe every year:
It is basically spray on clear bra.
Amazon.com: 3M 90000 Paint Defender Spray Film: Automotive
I just use a lot of blue painters tape. If you buy the widest size, it doesn't take that long to cover the key areas...
Attachment 48375566
I will add one more comment on the painter's tape. I apply a coat of Rejex every 2 or 3 months, and use Mequire's Ultimate Quik Wax just about everytime I wash the car. Sometimes I have a heck of a time getting it to stick to the car. The ends just immediately lift up. You can make it work with patience, but it does make the task a bit more tedious. Once you get it on though, it seems to do OK for the weekend.
It might just be the tape I'm using (Lowes cheapo bulk stuff). I've seen other guys use stuff that looks a lot more expensive. If anybody knows of any brands that work better than others (and don't cost an arm and a leg), I'd be interested.
And for what it's worth, when I peeled it off the mirrors two weekends ago, it definitely had some noticeable dings in the tape....it was worth the time and effort.
One last comment: Interesting, I guess the mudflaps on the GS protect the paint behind the rear wheels...I've got absolutely no road rash behind the rear wheels. I also don't really get any damage behind the front wheels either. But the rear brake ducts and the mirrors take one heck of a beating!
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
You could always do what I do.
Seriously, another thing you can consider is contact paper from Home Depot. I've used the clear in the past and it works great. I also autocross my black DD '06 and I use black contact paper. It works perfectly and is MUCH stronger than blue tape, and nowhere near as obvious as the blue tape.
For parking lot autocrosses, I just use Scotchcal (clear film with an adhesive). I don't care to apply painter's tape before every autocross. So I use Scotchcal or, for my C6 Z06, Cleartastic (with the adhesive, not the static cling one). Replace every year or two, car always looks good, and it's protected. For my C5 Z06 I made some simple splash guards out of a flexible composite material (barely noticeable) and the C6 Z06 has the Apsis splash guards. That really saves the rockers and lower fender/doors from the debris kick-up from the sticky R-compound tires.
I've always had good luck with Meguiar's cleaner/wax (the one in the brown bottle) to clean up pylon marks and apply some protection at the same time.
I used to use painters tape and a lot of it. Took a lot of time to apply. Now I use Road Warrior Plus. It is a roll on paint protection that works really well against rock, debri, sand, rubber, tar, etc. Follow the directions and it peels off when you are done. I like it better than the spray on because I don't have to tape and paper to keep it where I want it. Goes on quicker. My .02. There are a couple of dealers, but you can buy straight from the company that makes it at their website. I think it is roadwarriorplus.com. Jery
Received 1,984 Likes
Oh man the answer is........duct tape!!!
Max G’s
I use a car bra, works perfect. I know of another Corvette guy that uses one too. No issues, for auto-x anyhow. For road course, make sure it does not flap at high speed.
I also run little rock guards they help a ton. I HATE messing with tape and such. Any chips, that is what Dr. Color Chip repair is for.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
www.roadwarriorplus.com
This stuff is really amazing. Roll it on with a small paint roller, it dries clear and protects. When or if you want to remove it just wet it and peel it completely off.
yeah that is my experience with the road warrior plus product. It is pretty amazing when the front of your car and the rocker panels are black with track and road crap, and you peel that stuff off to reveal perfect shiny paint. Jerry
