Fresh Lingenfelter/ASA LS1 motor for sale
Old 08-14-2013, 04:19 PM
bosco022
bosco022's Avatar
Default Fresh Lingenfelter/ASA LS1 motor for sale
I had this ex ASA LS1 freshened by Byron Koury Racine Engines in Deland, Fl for use in an SCCA GTA Stock Car. I am now going to build a tube frame 1969 L88 Type Corvette with a more powerful LS motor.
Byron Koury is an excellent, well known race engine builder in the SE with much LS experience
Therefore this really nice, fresh, zero time LS1 for sale
Details:
* ex Lingenfelter ASA short block with Katech Rod Bolts
* fresh 243 heads replacing the 853's
* new Crane 550 lift cam power range 2600-6600
* upgraded push rods
* Comp rocker trunion upgrade
* ISKY 165-A valve spring
* ATI ASA Damper
* set up for carb at this point with Edelbrock Performer RPM intake
can be reconfigured for EFI
* MSD 6010 timing module
* Cloyes premium timing chain set
5000 firm... as wet sump motor
5500 firm... with single stage ASA dry sump with moroso ASA dry sump pan
bosco022022 at yahoo dot com
Old 08-29-2013, 08:03 PM
bosco022
bosco022's Avatar
*****************sold******************
Quick Reply: Fresh Lingenfelter/ASA LS1 motor for sale
