F/S Dry sump system for LS ,, new
Old 08-29-2013, 10:57 PM
msracing
msracing's Avatar
Default F/S Dry sump system for LS ,, new
F/S Aviaid LS Block mount dry sump 3 stage system ,, 3 stage pump Block mount,,,, Aviaid Dry sump pan with integrated Screens,,,,, AtI super damper with HTD drive hub and drive belt... Everything is new ,, the pump and pan was installed on a motor for some test fit,, the AtI was never out of the box...
This system was going to be used on a road race motor build but I Later decided to purchase a new built motor that already had a dry sump system installed... only thing you will need is a dry sump tank ( Petterson,Moroso or get one made up to your specs) of your choice and a remote oil filter and you will be good to go...
Sold
Manny 305-333-4445
mannysanchez360@gmial.com
http://aviaid.com/schems/3sbddss.gif
[IMG][/IMG]
Old 08-30-2013, 12:33 PM
Maynor29
Maynor29's Avatar
That's a nice deal for someone..
Old 09-01-2013, 03:41 PM
NemesisC5
Support Corvetteforum!
NemesisC5's Avatar
Does the pump mount where the A/C compressor is located?
Old 09-04-2013, 09:28 AM
msracing
msracing's Avatar
ttt
Old 09-04-2013, 01:27 PM
jstout
jstout's Avatar
Chattanooga Area Events Coordinator
Nice set up. Jerry
Old 09-04-2013, 09:21 PM
msracing
msracing's Avatar
thanks it a great system
Old 09-06-2013, 08:52 PM
msracing
msracing's Avatar
ttt
Old 09-08-2013, 10:48 AM
msracing
msracing's Avatar
bump
Old 09-13-2013, 08:21 AM
msracing
msracing's Avatar
tttt
Old 10-01-2013, 07:36 AM
msracing
msracing's Avatar
tttt
Old 10-27-2013, 10:36 PM
msracing
msracing's Avatar
ttt
To F/S Dry sump system for LS ,, new
Quick Reply: F/S Dry sump system for LS ,, new
