A arm bushings....
Old 09-01-2013, 08:52 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default A arm bushings....
After my last track day I noticed my bushings are about disintegrated... what's the best cost effective replacement? And can I just cut the old out and put in the new? Or do they need pressed?
Old 09-01-2013, 09:09 PM
71corv
71corv's Avatar
St. Jude Donor '08
To replace the bushings you either have to buy new a arms or replace the old with poly bushings. There are no oem bushings available. Went thru this a few months ago and settled for the poly.
Gene
Old 09-01-2013, 09:16 PM
Solofast
Solofast's Avatar
Been covered here to a pretty good extent.
http://forums.corvetteforum.com/auto...s-options.html
Another option is to go for the T1 control arms, and these last a bit longer but sooner or later you'll be in the same place where you are now in a few months. The cheapest and easiest fix is to flip the rear bushing as described in the link above. Cheap easy and fixes the problem....
Old 09-02-2013, 08:18 AM
CHJ In Virginia
CHJ In Virginia's Avatar
No cheap easy replacement available. You could contact a couple of the Vette Recyclers that are forum vendors to purchase used arms. My recommendation, since you track the car, is to just go ahead and install the poly bushings. Fix it once, fix it right and be done with the situation. You will like the difference on track !
Old 09-02-2013, 09:23 AM
braknl8
braknl8's Avatar
http://forums.corvetteforum.com/auto...l-arm-kit.html
Old 09-02-2013, 12:12 PM
sperkins
sperkins's Avatar
I have for sale:
A) Pfadt Poly bushing kit.
B) All 8 C5 control arms with Pfadt Poly bushing kit already installed.
Old 09-02-2013, 01:45 PM
froggy47
froggy47's Avatar
http://forums.corvetteforum.com/c5-p...l-arms-t1.html
Old 09-02-2013, 04:37 PM
VGLNTE1
VGLNTE1's Avatar
OK so...I see poly ones at jegs for 40$, then pfadt for 300$....paying for the name only?
Old 09-02-2013, 04:58 PM
braknl8
braknl8's Avatar
Not even close.
Old 09-02-2013, 05:11 PM
DarkMastyr
DarkMastyr's Avatar
On this topic, what does everyone think about how these bushings look? This is on the driver's side. The one on the right looks a bit scrunched to me, and it seems like there's been some rubber that has extruded from the core.
Old 09-02-2013, 05:23 PM
braknl8
braknl8's Avatar
You need the set of pfadt polys that the op doesn't buy...
Old 09-02-2013, 07:18 PM
sperkins
sperkins's Avatar
With those, you have to reuse the pins inside the rubber bushing.
That means you have to figure out a way to remove the bushings from the aluminum pins. You can try to cut and grind them off or burn them off, but you'd be crazy to do that. It's a complete waste of time and money.
Originally Posted by sperkins
I have for sale:
Holy cow I literally have 7 PM's about these. Going to respond to them all now.
Old 09-02-2013, 07:45 PM
sperkins
sperkins's Avatar
On 2nd thought, I'll just post it here since the OP asked as well.
A) Used Pfadt Poly bushing kit. $200 shipped.
B) All 8 C5 control arms with Pfadt Poly bushing kit already installed. $600 shipped.
Old 09-02-2013, 10:08 PM
froggy47
froggy47's Avatar
It's started to move, but not too bad yet.
Old 09-02-2013, 10:31 PM
dvandentop
dvandentop's Avatar
i got a set of vbp used poly bushings as well complete if anyone interested for a c6z.
To A arm bushings....
Quick Reply: A arm bushings....
