LS2 dry sump conversion
Can someone tell me what is needed to do a dry sump conversion on a 2005 C6 with an LS2?
I am thinking about doing this on my car but I need to retain air conditioning, so a full on race car setup is not going to work.
I'm thinking of LS7 parts for most of it:
Oil pan
Oil tank and lines
Oil pump
Timing cover
I was told I need a long nose crankshaft to drive the pump as well, along with the matching crank damper and key.
Can I use all factory parts for this or do I need some aftermarket parts? What are recommended parts for this conversion?
Thanks!
Oil pan
Oil tank and lines
Oil pump
Timing cover
Thanks!
Thanks guys.
Does the Aviaid LS-A system require you to change the crankshaft, like you would if you were doing the factory Z06/GS setup?
What's the approx. labor cost on a job like that, Doug? I'm somewhat local to you guys, being in the Philly area. I'm not sure if that's a project I can DIY.
Track Junky
Are you bent on keeping the LS2 motor? I did a dry sump LS3 conversion in my old 2005 Z51. Direct motor swap with a couple custom wiring harnesses and relocating the battery to the trunk. Kept the car as a street car but felt much more comfortable (in terms of motor not having oiling problems) on the track with Hoosiers...
http://forums.corvetteforum.com/c6-t...-sump-diy.html
taken19-
Thanks, but I don't have any plans on changing the engine. I thought the LS3 has more oiling problems than the LS2, but I guess I'm wrong. I'm not trying to turn this into a big $$$$ project right now.
Track Junky
The cost of going true dry sump or converting a 2005 into a GM dry sump may come close to buying a slightly used LS3 dry sump and selling what you have now.
I was just offering a potential solution that you may not have thought about yet. I spent $6700 on a dry sump LS3, throttle body to flywheel. You can probably sell a used LS2 for $3000-4000.
Thanks, I appreciate the suggestion.
I looked into doing the factory conversion- it's about $3200 give or take, depending on what parts I may have missed along the way. That would give me exactly what a Grand Sport has for dry sump. I think the Aviaid or ARE solutions are a fair bit cheaper- that Aviaid LS-A setup is something like $1800. If that's all that is needed, I wouldn't get a factory setup at all.
I don't care about originality or anything, just wanted to make sure that I can keep the A/C so it's a proper dual-purpose car, as I have no intention of converting it into a race car.
I spoke with someone today that said the factory LS7 uses external pump for scavenging purposes only and a conventional oil (pump behind timing cover) to oil the engine. Can someone tell me if this is correct?
Quote:
That is correct, the benefit is from the better supply of oil to the pump.
No, that is not correct. The factory LS7/9/, LS3 man trans, has two pumps, a scavenge and pressure, mounted behind the timing cover driven by the crank.
