2005, or 2006 and up chassis?
Old 09-07-2013, 02:46 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Default 2005, or 2006 and up chassis?
I remember hearing, or reading somewhere that there are reasons not to build a track car on an '05 C6 chassis; to make sure you get an '06 or newer. Problem is, I cannot remember why.
Anyone care to explain?
Old 09-07-2013, 03:16 PM
froggy47
froggy47's Avatar
Old 09-07-2013, 08:35 PM
CHJ In Virginia
CHJ In Virginia's Avatar
As far as I know there is no difference unless you are talking a steel frame VS the aluminum Z06 frame. The Z06 frame is lighter and tougher to attach a roll cage to. Both are VERY sturdy designs.
Old 09-08-2013, 12:58 AM
RX-Ben
RX-Ben's Avatar
05 is an oddball.
There is something with the trans/diff mounts that is different - not exactly sure.
It doesn't have CAN bus, which can be an issue when adding a datalogger.
There might be other stuff.
Old 09-08-2013, 02:35 AM
steponc
steponc's Avatar
St. Jude Donor '14
Default 05 oddities
When I went to update to 2008 differential and RSG trans. in my
C5 Z06 I used a 2005 cradle since it would accept my C5 lower control arms. I was already switching to coil overs but if I wanted to use a transverse spring I would have to use an 06/up cradle and lower control arms because the spring would interfere with the shocks.
Another item I needed was the offset differential mounts.
Old 09-08-2013, 10:31 AM
RX-Ben
RX-Ben's Avatar
http://forums.corvetteforum.com/1563694469-post5.html
To 2005, or 2006 and up chassis?
Quick Reply: 2005, or 2006 and up chassis?
