What brand rotor do i have? Need new rings
Here's a pic of one. Came with the car when I bought it. Needs new rings now. What brand are these? Where do u get new ones? Also never had 2 piece rotors...wat would be the tq spec and is there a certain procedure or sequence. I would think u would wanna use loctite? Any input, never did this before and I track the car so I wanna know the correct way.
Received 8,924 Likes
It isn't an AFX/Coleman rotor either as they also use a different bolting mechanism. I attached a picture of my cracked Coleman rotor.
Bill
Its got a nice ridge on the outside edge so I assumed its starting to getting thin. If an indication of min. thickness is the slots disappearing then ill put them back on and use them. However I would still like to see if anybody knows the brand, so I can order them when they do wear out.
Thx its money I can spend elsewhere for the car.
Those are DBA 5000 (Disc Brakes Australia) rotors, same as I have on my car. Rings are available from any DBA dealer and they come with new Nylock nuts.
Checkout KNS Brakes in Raleigh, NC - forum vendor - they have the best price on replacement rings I have found.
Installation requires a Tri-Y bit that can be hard to find and is expensive. Mine cost $22 plus shipping. It is like a phillips bit but with only 3 blades, nothing else will work.
Installation is easy once you figure it out. New mylock bolts are shipped with rings, one use only ! Use the tri-y bit to hold bolt and use ratchet to remove nuts. Install all new nuts on bolts finger tight and torque down in two rotations using a modified 90 degree star pattern.
I don't remember what the torque spec is right now, but it is included on instruction sheet with rigs. Torque spec is in INCH POUNDS or NEWTON METERS, you will need a small 1/4" torque wrench measuring inch pounds, your standard 1/2" ain't gonna cut it !
