SCCA full cage and side windows
Old 09-10-2013, 02:52 PM
Sebring27
Sebring27's Avatar
Default SCCA full cage and side windows
Hi,
I am just about to have a full SCCA cage fitted to my C5 Z06.
Will this mean that I will lose my side windows completely?
My installer seems to think not BUT I thought I would ask the racers on the site as they will surely know. Not that I need the windows particularly, only when towing in the rain with an open trailer ?
Thanks in advance !
Old 09-10-2013, 03:55 PM
taken19
Track Junky
taken19's Avatar
I'm pretty sure if you run NASCAR sidebars, there's no hope for windows or interior door panels.
Old 09-10-2013, 04:03 PM
spazegun2213
spazegun2213's Avatar
I've never seen a cage that had nascar bars and windows... ever.
Here is a question to the OP, why are you worried about saving the windows when you are putting a cage in the car?
Old 09-10-2013, 04:19 PM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
I think RAFTRACER'S (Danny Popp) NASA car has windows and NASCAR bars.
Old 09-10-2013, 04:47 PM
Sebring27
Sebring27's Avatar
Keeping the rain out when towing on an open trailer.
Old 09-10-2013, 04:59 PM
spazegun2213
there are other ways of doing this. I know most of them, as I towed my c5 on an open trailer for years without window.s
Old 09-10-2013, 05:02 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I have seen several cars locally that have the side bars and have retained closable windows. They were done by Piper Motorsports in Northern VA. Door panels cut away and power junk for window was removed. Track window guides stayed and the window is pulled up and secured by a strap. You lose a little side room, but not much, maybe an inch or two.
Old 09-10-2013, 05:24 PM
Sebring27
Sebring27's Avatar
Great, any special tips?
Sebring27
Sebring27's Avatar
Many thanks for the info much appreciated !
Old 09-10-2013, 05:56 PM
Sebring27
Sebring27's Avatar
If you would like to share your wisdom and experience with a few tips it would be appreciated and do not fancy getting the interior drenched !
Thanks !
Old 09-10-2013, 06:13 PM
taken19
Track Junky
taken19's Avatar
I bought a sheet of 1/8" lexan from Lowes and used a dremmel to cut each side to fit. Took a bit of patience, but the lexan and 3" painters tape will keep all (or most) of the rain out when towing.
Old 09-10-2013, 06:18 PM
Sebring27
Sebring27's Avatar
Many thanks !
Old 09-10-2013, 06:22 PM
taken19
Track Junky
taken19's Avatar
Here's the best pic I have of the lexan windows.
I put black gorilla tape on the edges to protect potential corners and fingers... Shoot me a PM if you have any questions.
Sean
Old 09-10-2013, 06:29 PM
Sebring27
Sebring27's Avatar
Sean
Thanks Sean - Fantastic ! Much appreciated !
Old 09-10-2013, 06:35 PM
3X2
3X2's Avatar
Yes, you can have a SCCA legal cage and retain functioning power windows. We've done dozens of them.
Old 09-10-2013, 07:14 PM
Paul Schmidt
Paul Schmidt's Avatar
Side windows still remaining with NASCAR door beams on both sides.
Old 09-10-2013, 09:04 PM
Sebring27
Sebring27's Avatar
Thanks to all who have replied
Many thanks!
To SCCA full cage and side windows
Old 09-10-2013, 09:31 PM
redtopz
redtopz's Avatar
I had a cage built and kept my power windows. Same builder who built Sawtelle's cage. Frank Fuller in Lodi, CA.
Old 09-11-2013, 10:27 AM
redtopz
redtopz's Avatar
I received your PM, but my "Premier" account expired and they won't let me respond without deleting about a thousand old pm's first so I'll just say it here.
Yes, definitely build the cage to scca and nasa specs so you can sell the car later. You can have it built in stages if you like. For example, just have the builder start with a roll bar with rear bracing that can later be modified with a full front cage. If you are in CA, then you might want to contact TC Design in Milpitas since they can handle not only the cage, but also the rest of the things you might want (steering wheel, seat, harnesses, etc.).
Old 09-11-2013, 10:55 AM
JohnAlley
JohnAlley's Avatar
Hi,
Thanks in advance !
I have full cage in my C5 with NASCAR door bars and windows fit fine. I have since removed windows for weight reduction but they fit fine with the full cage and door bars.
Quick Reply: SCCA full cage and side windows
