Adding vented hood before going to full aero?
Old 09-23-2013, 08:46 PM
StreetSpeed
StreetSpeed's Avatar
Default Adding vented hood before going to full aero?
Folks,
Does it make any sense to piece together an aero setup? I know you can't really go spoiler unless you go splitter and front breather and that's a pretty big commitment. But the C5 could certainly use a little less lift at high speed in the front end and I was wondering if a vented hood only can make strides in that department? If so anyone have a recommendation for a hood that reduces front end lift the best?
Old 09-24-2013, 12:50 AM
Last C5
Last C5's Avatar
Originally Posted by StreetSpeed
Folks,
Either one of ACPs hoods do a great job. And you will feel a noticable difference the first trip down the straight away.
Old 09-24-2013, 01:41 AM
SunnydayDILYSI
SunnydayDILYSI's Avatar
Old 09-24-2013, 09:14 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
Jim
Old 09-24-2013, 11:48 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Vented hood helps even before aero
Old 09-25-2013, 07:37 AM
davidfarmer
davidfarmer's Avatar
you will see the difference also, you hood will no longer bulge upward from the pressure tracked in the engine bay. Re-direct air that is spilling under the car, so that it is "sucked" out of the top, and you get an overall reduction in lift.
You have to kill the bottom-breathing style of the C5 to make any downforce at all, but every little bit helps as far as I'm concerned.
Old 09-25-2013, 07:44 AM
davidfarmer
I had a set of these made in Aluminum for a customers car, very reasonable and easy to rivet into place. Not as fancy as a custom hood, but effective. I don't have a finished photo handy
Old 09-25-2013, 07:29 PM
StreetSpeed
Thanks David. Not sure what I'm looking at here though? Vented aluminum panel? Cut the hood out and rivet that in place? I own a machine shop so I could crap that out in a matter of minutes, but not sure how I feel about my skills cutting the hood to pieces. Have a DXF file by any chance?
Old 09-26-2013, 10:20 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
You can google hood louvers and there is a website that sells louvers similar to what David is showing.
http://www.hoodlouvers.com/racinghigh-performance/
Old 09-26-2013, 10:30 AM
Shaka
Shaka's Avatar
Received 1,331 Likes on 790 Posts
Also those headlights in the up position kills lift that the fenders generate.
Old 09-26-2013, 03:18 PM
moespeeds
moespeeds's Avatar
That looks really interesting.
Old 09-27-2013, 12:41 AM
crimlwC6
crimlwC6's Avatar
i converted my c5 to a front breather with a cheap duraflex front mini splitter (2 inches) and vented my front hood and laid my radiator forward. I run no rear wing and either 305 or a 315 square setup and the car runs great. A front vented hood is a good investment. IMO modifying your own hood is the way to go.
Old 09-27-2013, 06:16 PM
RDnomorecobra
RDnomorecobra's Avatar
I've been thinking of finding a junk yard hood to cut up and keep my stock one untouched. I might just have to do it now.
Old 09-28-2013, 01:03 PM
Z06Tracker
Z06Tracker's Avatar
David is talking about my car. Yes, there are two vented aluminum panels. I don't have access to the car right now, but can post a pic next weekend. I wouldn't worry about your skills cutting the hood. The opening will be smaller than the panels, so it really does not matter what it looks like under them.
To Adding vented hood before going to full aero?
Quick Reply: Adding vented hood before going to full aero?
