Oil on your slicks
Old 10-14-2013, 11:42 AM
jbondfl
Support Corvetteforum!
jbondfl's Avatar
Location: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Default Oil on your slicks
Okay folks, "hypothetically speaking" LOL, if you happen to roll your car through a SERIOUS oil puddle in the paddock are your tires ruined? Only one tire actually, a rear one, but is it a throw away now or can you simply wipe it down and be fine? Tire has one weekend on it.
Thanks in advance.
Old 10-14-2013, 01:31 PM
froggy47
froggy47's Avatar
Just drive it off track for mile or so, then when you go back on track do a couple of easy laps. The tire rubber is not going to suck the oil deep into the tread like a sponge.
Old 10-14-2013, 05:01 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Should not be a problem. Drive first lap or two easy if it is a front. If it is a rear, do a short quick burst to spin em on pit out and you will be fine.
Old 10-14-2013, 05:52 PM
ScaryFast
ScaryFast's Avatar
It's junk and also toxic to you and the environment. Better send it to me immediately for proper disposal.
Old 10-14-2013, 07:42 PM
blkbrd69
blkbrd69's Avatar
Better yet red cars have better luck on ruined oil soaked tires. The whole set is contaminated and I can have them out of your garage Friday
Run them clean....Just not at turn 1.........
To Oil on your slicks
Quick Reply: Oil on your slicks
