Race Seat Harness Question
Old 10-20-2013, 05:26 PM
w00tw00t
w00tw00t's Avatar
Default Race Seat Harness Question
Hey Guys - I have a race seat installed in my Z06..OMP ARS with Planted Brackets custom modified by Dan from Vetteworks.
If I just keep the seat belt receptacle yellow connector plugged in (using Vetteworks airbag sim) but not plug in the grey/purple and black connectors – and not install the ****** grey box .. will this throw any codes? or errors? I hate the tangle mess of wiring and the two plastic boxes under the seat. I just want to keep it simple and only plug in the seat belt receptacle..
I don’t care about telescope function as my seat is hard mounted.
Cheers
Vivek
Old 10-20-2013, 05:46 PM
CONE RACER
CONE RACER's Avatar
I don't use a sim plug (so I see the air bag light), but no errors, CEL, or anything.
Old 10-20-2013, 05:53 PM
w00tw00t
w00tw00t's Avatar
Awesome. Thanks!
Old 10-20-2013, 06:16 PM
Charley Hoyt
Charley Hoyt's Avatar
Check out this post I did about airbag simulators....it shows an easy way to handle the drivers side.
http://forums.corvetteforum.com/auto...race-seat.html
Charley
Old 10-20-2013, 06:20 PM
w00tw00t
w00tw00t's Avatar
My question is what happens if I only plug in the yellow connector and leave the other two (black and purple) connectors unplugged. I have a fixed race seat with no slider so I don't care about the telescoping steering.
Old 10-20-2013, 09:11 PM
Charley Hoyt
The air bag light will be on and the air bag will not function. Also the telescoping wheel will not function. If you are not going to use all three simulators you may as we'll not use any. If you want the air bag to operate you need all three.... If you don't care if it operates, you don't need simulators.
Charley
Old 10-20-2013, 09:46 PM
w00tw00t
w00tw00t's Avatar
yep thanks! for the record I just removed the harness and the car didn't flip out.. primarily a track car: I'm going to be running 6pt harness etc.
To Race Seat Harness Question
Quick Reply: Race Seat Harness Question
