Just looked at a 122k Viper and immediately saw a glaring engineering flaw...
Looking through the front grill of this showroom vehicle, I noticed that a stacked plate cooler of some type was mounted upside down, so that both the inlet and the outlet were facing the ground. All plates were horizontal. How could this happen on a brand new vehicle of this caliber?
The car was immaculate race version new Viper,... I couldn't believe it when I saw it.
I have never seen anything that suggested it was a good idea to mount both inlet and outlet on the bottom. But OEMs tend to be smart, or at least test things, so they may have found a different result in practice.
Depends on the internals of the cooler. I bet it is right!
Jim
Jim
I imagine the oil pressure will feed the oil to the top of the end tank before it gets dispersed across the plates. As long as the combined plate area is similar to the tank volume it will be fine.
Jim
As long as the "oil system" has no way of exceeding ambient pressure when "off" and even if it completely drains, the system when charged better be able to create enough oil pressure to displace any air that is in the plate cooler when the motor is running/oil pump working.
Yeah, I hear all the responses basically defending it, but to me from an engineering standpoint, it seems kinda like using 4 lug nuts on a wheel that has 5 lug holes. You can do it, and nothing is going to blow up, but it's just not right.
That's how I see it anyway.
You must push oil into the bottom, and allow it to flow up through to the top. That is the way to getting maximum cooling efficiency.
Maybe I'm wrong though. It has happened a time or two before.
