Tick/Tilton Clutch Master Cylinder Use Reviews
The master cylinder (MC) on my C5 has given up the ghost, so I am at the crossroads of deciding what to replace the MC with. OE? Tick? Tilton? I use the car for HPDE's and daily driving. I do not plan any major performance modifications (at most a mild heads/cam setup) in the distance future. Goal is building a reliable car the still retains good street manners. As a experienced Mechanical engineer I am trying to get through the marketing crap and find out the facts and get some real feedback on Clutch MC use, as most reviews, like myself, are replacing faulty MC's, so naturally the reviews tend to be positive.
So first things first. . .
DESIGN
OE - Plastic body? Piston Bore Diameter? Piston seal design? Part metal hard line and flex line. No heat shielding on line. No adjustment needed.
Tick - Aluminum body. Appears to be based on Tilton 75-series M (Reference Link) Piston Bore Diameter? Piston seal design? Adjustable shaft length. Stainless steel flexible hydraulic line. Heat shield on hydraulic line. What "expertise" was employeed into the Tilton MC that makes its more effective and reliable? What are the "few NASCAR concepts" used?
Tilton - Not sure if this even exists as a off-the-shelf kit, but I read that someone used a smaller piston bore tilton MC for C5.
CLUTCH USE/FEEL
OE - Well this is simply the baseline. It provides enought travel to allow feathering of the clutch on the street. Allows smooth feathering during downshifts with imperfect rev matching to avoid sharp weight upsets.
Tick - This is where I am looking for some good feedback. Sure it fixes everyones faulty clutch MC problems, but what is it like to daily drive with a Tick MC? What about road racing? Ultimately the cylinder bore is going to be the primary factor in how the MC behaves compared to the OE MC. If it is much bigger than the OE, then clutch engagement will occur much more rapidly, with much less pedal travel. This is something that I would tolerate to some extent, but I am NOT looking for an ON-OFF switch that supports drag racing.
I think I have said enough, so I will shut-up and let you guys and ladies share your facts and experiences.
DESIGN
CLUTCH USE/FEEL
I'm going to play devil's advocate here. Why do you really want to install something other than stock OE cylinder ? Is there some specific benefit you want from an aftermarket unit ? OE works well in street and HPDE applications especially if you place a heat shield around the line. They cost less than the aftermarket units and are specifically engineered for the application. IMHO don't waste time with a lot of analysis, just install OE and drive that car.
You can install a stainless line on the OEM clutch master - http://www.speedwaymotors.com/LS1-an...ing,25017.html
I have had zero issues with it or the OEM master in many years of use.
You can also add a tie-rod setup and adjust pedal height with some work, which I think is the main benefit of the Tick setup.
Unless you have pedal sticking issues, usually associated with higher hp motors, the stock should work fine. The pedal adj is a benefit, but from my understanding, the pedal should be adj to where clutch is properly disengaging, not to where it is comfortable. I ran a stock mc on my 500rwhp without issues on the road courses, but have never done the 1/4 mi stuff.
I went dragging with my '01 (386whp, 52k miles)
Clutch started the stick. Just got the Tick MC and Mcleod RSD and the whole bit but I hear the Tick may make the pedal stiff. I guess there are two different options with Tick. I hope mine works good! It was the only option I saw on their site
Don't quote me but I think there is a MC from tick with either a 3/4" bore or a 7/8" which is standard. The 7/8 allows more fluid which stiffens the clutch so the 3/4" would be ideal for dd.
Here is a little more info: http://forums.corvetteforum.com/c5-z...post1585235151
When I looked on the website I saw one option and didn't bother to call. I hope I didn't make a mistake!
FWIW, have one 3/4" tilton 75 series m/c still available for sale. I recently sold one to another member who had the tick setup with the larger m/c and decided to go to a smaller m/c for softer and longer stroke pedal more like the factory setup.
Not certain what the oem MC costs but Ram sells a modified oem with adjustability
http://www.texas-speed.com/p-1120-ra...-corvette.aspx
I never owned a Tick so no experience except that I heard install was more difficult than oem unit, I believe due to space restrictions. On my 2002 C5z I installed a Mcleod and pedal feel was like oem and install was relatively easy. Definitely fixed the "creeping issue" and allowed 7100 rpm shifts without issue.
That would me! Really like the 3/4 bore over the 7/8. Stock feel.
Just installed a Tick clutch master last month as I was having issues with my C6Z06 clutch sticking to the floor.
Works as advertized, clutch feel is improved over stock with a more linier engagement. May be due to the stock spring adding a wierd double sprung feel?
May be slightly firmer than stock but has a better feel to me. The real test is my wife really prefers the feel and says its better to drive now.
Kind of a PITA to install vs the stock one but worth it once done.
The thing I really like is shifting into 5th at speed is smoother with better feel. could care less about drag racing, but it excells on the road course when the trans. fluid is hot. Would occasionally grind 5th now I dont.
Anyone that thinks the Corvette was engineered with heavy HPDE use in mind is kidding themselves. A plastic master cyl.? please. Not to mention the bleeder setup?
I've had the Tick about 2 months now and it is definitely a harder stroke. It's taking a while to get used to the quick release near the top; however, my shifts are much cleaner and my twin-disk RPS seems to like it. I haven't had it to the track since installing but would expect easier shifting at flat out RPMs.
