AVIAID Dry Sump System
Old 10-23-2013, 06:56 PM
J.R.
J.R.'s Avatar
Default AVIAID Dry Sump System
FS: Aviaid 4 stage dry sump system
With ARE pan and ATI damper
crank pulley and belt system included
all fittings and lines
(No tank)
$1575 plus shipping within Continental US
This was a dry sump system off a car I purchased and was kept as a spare. Selling car so do not need system.
http://s1145.photobucket.com/user/co...?sort=3&page=1
Old 10-23-2013, 09:48 PM
redtopz
redtopz's Avatar
That's a good deal.
Old 10-24-2013, 03:27 AM
trackboss
trackboss's Avatar
Never seen a setup with such an extension before between a stage. What is it for? I'd think the motor mount would need some serious modification to make that work.
Old 10-24-2013, 09:33 AM
J.R.
J.R.'s Avatar
V,
This setup was on an LS6 that I think was built by Guldstrand.
This was not on engine at time I purchased car as car came with wet sump LS6 and I swapped my already built dry sumped LS3 into the car.
I just kept it as a spare. i have not checked clearance issue with motor mount but I know it was installed on my present car with a built LS6 at one point in time.
J.R.
Old 10-24-2013, 04:12 PM
jimtway
jimtway's Avatar
Most likely its an air/oil separator.
But nevermind, the plumbing isn't right for that. maybe they needed to space out the last stage for clearance purposes.
Old 10-24-2013, 10:18 PM
J.R.
J.R.'s Avatar
Jim,
I believe you are correct. It appears that end of 1st section and narrowing occurs at start of motor mount (apparently for clearance).
Old 10-27-2013, 10:46 PM
J.R.
J.R.'s Avatar
Default Dry sump
sold
To AVIAID Dry Sump System
Quick Reply: AVIAID Dry Sump System
