DIY Alignment Threads?
Old 10-25-2013, 06:29 PM
DannyBoyC6
DannyBoyC6's Avatar
Default DIY Alignment Threads?
Can someone please point me to the best / stickiest thread(s) for info on checking / adjusting alignment on my C6? I've done enough track time (and grass / dirt time) that I really want to verify my current alignment and learn how to adjust for a mild track setup without going to a speed shop - if it is reasonably doable for the weekend mechanic type.
Someone mentioned David Farmer's site on another thread, but it is shut down. Does YouTube have any good tutorials for our cars?
Thanks in advance -- you guys are always a wealth of knowledge!
Dan
Old 10-25-2013, 06:45 PM
froggy47
froggy47's Avatar
Here is how to set toe, I need to do one on camber, next time I do it.
Lot's more at froggy's garage on yt.
DRLC5 (10-12-2015)
Old 10-25-2013, 06:55 PM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
good settings to start with found in the suspension section:
http://forums.corvetteforum.com/auto...e-learned.html
Old 10-26-2013, 01:23 PM
dbratten
dbratten's Avatar
David Farmer has had his information linked off his FaceBook page for some time now. Here's the Alignment guide many of us use.
--Dan
Old 10-26-2013, 06:55 PM
DannyBoyC6
DannyBoyC6's Avatar
Those settings are very helpful - thanks!
Old 10-26-2013, 06:57 PM
DannyBoyC6
DannyBoyC6's Avatar
--Dan
Just Liked it and saved off the torque specs, alignment guide, and camber plate PDF. Thanks very much!
Old 10-26-2013, 07:19 PM
DannyBoyC6
DannyBoyC6's Avatar
Thanks very much, Froggy! Very detailed video.
Old 10-12-2015, 06:57 AM
DRLC5
DRLC5's Avatar
Corvette C5Z setting toe alignment using strings by froggy - YouTube
Great info.
Old 10-12-2015, 01:19 PM
froggy47
froggy47's Avatar
Originally Posted by DRLC5
Great info.
Thanks!
To DIY Alignment Threads?
Quick Reply: DIY Alignment Threads?
